Old 12th September 2011, 08:28 PM   #1
Default Adcom GFA-555 + Onkyo TX-NR709 Mute Thump?
I recently changed out my receiver and main amp for an Onkyo TX-NR709 receiver and an Adcom GFA-555. After much tweaking, I am still left with a medium level thump when I do various things such as changing inputs on the receiver, muting, change channels on the cable box, and sometimes during commercials on TV (likely a switch from national to local programming). I have tweaked the receiver so that it is not changing surround modes during any of these switches, but I am still getting the thump.
I suspect that the reciever is muting during these operations by clamping the input and that is causing the issue. I also have turn on/off thump from the Adcom so it may have some DC offset.
My question is how should I go about diagnosing and correcting the problem?
Thanks,
-Stu
Old 12th September 2011, 09:15 PM   #2
I took some measurements (no audio) while not muted and muted and here is what I found. These are DC offset measurements in MV at the speakers.
Adcom GFA-555: [mains]
--Not Muted
L=45.4, R=16.8
--Muted
L=40.3, R=10.7
Adcom GFA-5400: [surrounds]
-- Not Muted
L=14.0, R=95.1
--Muted
L=9.7, R=90.0
Since I am using Klipsch speakers all around, this thump is very annoying. Should I just live with this or is there a way to tweak the DC offset in the Adcoms? Or, am I on the wrong track here?
Thanks,
-Stu
Old 13th September 2011, 12:48 AM   #3
Do not change the DC offset , it will have no affect on the thump. The "thump" will not damage you speakers. You can try a 10 ohm resistor with a .1uf cap across the speaker term and see if that helps. resistor to pos and cap to neg. Use a high quality film cap, this has helped some of the 555's I have had, depends on the preamp/processor your using also. Some of them short the line out when in mute, some just cut the signal down which is better to me.
Adcom gfa 555 help 406vette Solid State 34 15th October 2011 03:34 PM
Adcom GFA-555 turn-on thump kman Solid State 4 29th May 2008 12:05 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 10:20 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
Page generated in 0.08345 seconds (72.32% PHP - 27.68% MySQL) with 10 queries
