Old 12th September 2011, 11:00 AM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default CROWN POWERTECH 1
CROWN POWERTECH 1 amplifier to repair but seems that the broken ventilator is space technology ...
The actuall ventilator has only 5 ( !!! ) cables and two windings while one of them is double
then again nothing is wrong with the amplifier except some electrolytics but protection circuits will "see" absense of ventilator ( if removed ) and will not allow amplifier to start
seems that schematic is not there ( crown web page ) so any information will be very welcome ...
Kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 12th September 2011, 11:19 AM   #2
sakis's Avatar
removed the vent and realized that is not really space technology more like a clever circuit
the ventilator has actually a primary winding to run the vent but on the same core there is a 18+18 volt transformer winded which probably goes to supply the protection circuits
theory will be if vent fails there is not going to be power to the auxiliary circuits so amp will not power up ...
Long run show that all worked fine and idea was good but the bearing of the vent failed before the coils .... ventilator become noisy cooling was not enough vent coil and boards boiled but seem to survive..
idea is to put any available ventilator ... add a small 18+18 trafo and a thermostat...
kind regards sakis
Old 12th September 2011, 11:23 AM   #3
sakis's Avatar
ohhh and by the way
local service center of Crown asked for 250 euros to replace the blody vent .....
Old 12th September 2011, 11:43 AM   #4
jez is offline jez  United Kingdom
I think that maybe when you say "vent" you mean FAN??
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 12th September 2011, 11:49 AM   #5
sakis's Avatar
yeap
Old 12th September 2011, 12:00 PM   #6
Send a message via Yahoo to audiomachines
you could try to disassemble the "transmotor" clean it and lubricate it with thick grease (I use WD40 to remove dirt from the brass bearings) a bit of light sanding on the shaft of the transmotor after cleaning it (to remove rust spot that would otherwise make the fan run noisy) If the clearance of the shaft and the bearing is too wide, you could try inserting shim brass of the appropriate thickness. Careful with the fan blades they are a bit brittle.
Old 12th September 2011, 12:08 PM   #7
sakis's Avatar
no i wont bother
will replace the fan with a new one to be on the safe side ...as said since the fan's power was low both coils and amp have obvious stress marks from heat ...
i will be more happy with a brand new one ...as about the trafo thingy i think i will do the same only wire the protection circuits in series with a thermostat ...
kind regards sakis
Old 12th September 2011, 12:24 PM   #8
signs of heat stress,wrong racking perhaps? air intake from the front and exits on the sides, unlike the usual front to back air flow.
Old 12th September 2011, 01:29 PM   #9
sakis's Avatar
can also be possible ...dont know amplifier is quite old
Old 12th September 2011, 01:36 PM   #10
I have a bunch of fan-formers removed from the MA series. Adding a few drops of synthetic oil to the bearings has restored them to good working condition. However they are not the model you seem to have.
The discoloration is normal as the coils get hot and all the dirt flows right by them in use.
The newer versions used a separate power transformer and fan.
250 euros is a very high price for this part!
Final test: Module Leco vs Crown Powertech Series Amplifier DjLeco Solid State 0 22nd March 2011 09:51 PM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
Crown DC300A Sheggy Solid State 4 3rd July 2008 01:52 PM
crown d150a khelben Solid State 19 5th June 2005 11:56 PM
QSC/Crown and the like Madmike2 Solid State 4 3rd May 2005 10:38 AM
Page generated in 0.09770 seconds (78.57% PHP - 21.43% MySQL) with 10 queries
