This old amp is good?
Old 11th September 2011, 10:04 PM   #1
tadiam1 is offline tadiam1  Argentina
Default This old amp is good?
See this....
Old 12th September 2011, 02:08 AM   #2
dangus is offline dangus  Canada
Hard to say. This amp doesn't appear to have any SOA protection for the output devices. And the output devices aren't complementary, so that's generally means compromised performance. I'm guessing a LM3886 chip amp would vastly outperform it, cost less to build, and survive errors like shorted speaker cables.
Old 12th September 2011, 09:04 AM   #3
ingenieus is offline ingenieus  South Africa
If you are going to build an amp, you might as well use modern components...
Judging by the +20V power supply it's not going to be hugely powerful.
Old 12th September 2011, 10:04 AM   #4
R.I.P.
A simple and typical LIN topology amplifier.
Added features:
CCS tail for the LTP
CCS load for VAS
Complementary drivers
Quasi complementary NPN outputs.
This will work as a basic low power amplifier. It will teach one a lot about how a simple LIN amp goes together.
It can be used as the basis for extended experiments on other features that can be added to improve performance and reliability.
I see the circuit as educational rather than music reproducing.
regards Andrew T.
This old amp is good?Hide this!Advertise here!
What makes a good amp good ? liquias Solid State 19 4th September 2010 12:42 PM
Easy & Safe & Good sounding gainclone tube buffer ionomolo Tubes / Valves 2 29th March 2009 11:41 PM
8233, 8116 & 6BZ6 valves - what are they good for? jack daniel Tubes / Valves 62 28th February 2008 01:04 PM
Good & simple chip amp for 2-ohm load? Otherwise Chip Amps 7 8th July 2003 07:21 PM
Help? good & cheap SPDIF out for PC net-david Digital Source 6 22nd May 2003 07:38 PM
