Old 11th September 2011, 06:10 PM   #1
Smile Electrolytic Cap can I replace with film
I can not get a straight answer on this hope you guys can help me. I have a Marantz Receiver and want to replace some of the small value caps (like 1uf, 2.2uf, and 3.3uf) with film caps on my preamp board. The ones I am finding are rated at 250V.
So 2 questions:
1. the caps I am replacing are 25V and 50V rated. I have seen on a chart on the web that you could use a 250V rated cap in it's place, is this ok?
2. Can you put a film cap in an electrolytic cap location that is polar, the films are not marked + or- also can you use a film to replace a non polae elec. cap?
Thanks!
Old 11th September 2011, 06:34 PM   #2
Ron AKA is offline Ron AKA  Canada
1. Yes
2. Yes, Yes
Old 11th September 2011, 06:45 PM   #3
Mooly's Avatar
As above from an electrical view.
From a mechanical, view if the films don't fit the print the result will look a mess. If you have to start adding wires to the caps then it's even worse as the length of wire destroys the very properties you are looking to improve.
A simulation free zone. Design it, build it, test it.
Old 11th September 2011, 07:35 PM   #4
dheming is offline dheming  United States
dheming's Avatar
The main problem is just the large physical size of the film caps vs e-caps. As was mentioned it's not really ideal to use long wires to connect them the the PCB. When doing this I like to use caps that have long enough leads to not have to use wire at all. Also the lower the voltage rating the smaller the film cap will be at the same uF rating. Generic mylars can be had in 100v.
You can also use "euro blocks" to allow easier swapping/rolling of capacitors. I did this on my cheap CDP a few years back: Modifying the NAD C521BEE You can see in post #2 how I got rid of the extender wires and just bent the leads themselves to fit into the euro blocks. They barely made it to them.
Old 11th September 2011, 09:05 PM   #5
jaycee is offline jaycee  United Kingdom
Look at Wima MKS2 series capacitors - these are all 5mm pin pitch and are great replacements for electrolytics in these situations.
Old 11th September 2011, 09:49 PM   #6
Hi, and thanks all for the help and quick replies. What value cap would you use to bypass a 1uf, 2.2uf or 3.3uf film?
Old 12th September 2011, 06:39 AM   #7
Mooly's Avatar
Doesn't need it
Old 12th September 2011, 09:53 AM   #8
jez is offline jez  United Kingdom
You are wasting your time money and energy on this!
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 12th September 2011, 04:19 PM   #9
indianajo's Avatar
I disagree. 20 year old electrolytic caps need to go. By that age about a fourth of them will be low value, unless super sealed long life grade (not found in consumer products, mostly). I don't know where you live, but lots of people stock 63v film caps here like newark.com and mouser.com. newark operates in about 50 countries as farnell.com. You can download the .pdf file from newark or mouser and figure out the size and lead length before you buy them. Some may be more suitable than others.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 12th September 2011, 04:31 PM   #10
Patfont,
Check the Panasonic V series stacked metal film. Their 1uF/50 part is as small as a 1uF/50V aluminum electrolytic.
Digi-Key - P4537TB-ND (Manufacturer - ECQ-V1H105JL3)
datasheet:
ECQV(L)/(M) Series | Film Capacitors | Passive & Electromechanical | Panasonic Industrial Solutions Global
Ignore the naysayers in this thread
Non-Polar Electrolytic vs. Polypropylene Film Capacitors gtforme00 Parts 24 23rd April 2011 03:33 PM
Replace Radial Electrolytic with SnapIn? bmoraru Parts 7 27th November 2010 04:22 AM
PSU capacitors: 30uF film ok instead of 100uF electrolytic? sharpi31 Tubes / Valves 3 13th September 2008 08:49 AM
Electrolytic to film - Retain the bypass in coupling app? HaflerFreak Parts 17 3rd March 2008 08:43 AM
film vs. electrolytic metebalci Tubes / Valves 9 6th August 2004 11:44 AM
Page generated in 0.10617 seconds (88.91% PHP - 11.09% MySQL) with 10 queries
