Parts placement in enclosure tips
Old 10th September 2011, 07:11 PM   #1
Frosteh is offline Frosteh  United States
Frosteh's Avatar
Default Parts placement in enclosure tips
I finally have all my parts to build my preamp/active xo/amp setup and I'm wondering if there are any tips to placing the various parts in the enclosure.
Enclosure: 16"x16"x4" aluminum from Par-Metal
Parts:
2 - Hifimediy T2 amps
1 - 200W toroid transformer
1 - small 20W SMPS
2 - miniDSP 2x4 (can be stacked)
and of course lots of RCA jacks and other jacks/connectors which will be on the back panel. Volume and input selector switch are on the front panel.
I'd like to minimize the amount of noise created by the placement of all these in the enclosure, so any help in placing them optimally would be appreciated. I have a 1/8" aluminum sheet laying around too so I can cut it down to various sizes and isolate parts if need be.
Old 10th September 2011, 07:27 PM   #2
digits is offline digits
digits's Avatar
aluminium isn't much use for shielding
Old 11th September 2011, 12:17 AM   #3
Frosteh's Avatar
Well I'll save that aluminum then. Is there any rules for placing components or is it more important to lay it out practically with minimal wiring?
Old 11th September 2011, 02:51 AM   #4
Ronj is offline Ronj  Singapore
IMHO, Keep your " small 20W SMPS" as far away from input section(RCAs) as possible...
Keeping miniDSP away also wont be a bad idea...
Of-course then follow the basic rules... RCA inputs should be as far away from IEC power socket as possible... Speaker outs can be between the RCA and your IEC power socket... So considering the orientation of your - Hifimediy T2, your SMPS could be best placed at the left most rear corner, with an IEC socket. toroidal transformer could be placed next to it... Since - Hifimediy T2 has a fixed pot... I guess It will come some where near right most corner near the fascia...
I could be wrong... veterans please correct me...
Parts placement in enclosure tipsHide this!Advertise here!
Toroid placement inside enclosure, stray field remmelt Construction Tips 1 16th December 2009 06:17 PM
Just ordered parts for UCD400 amp, what enclosure should I get? CptanPanic Class D 3 4th July 2009 05:14 PM
Driver placement & enclosure design help DPK Multi-Way 1 16th June 2005 09:37 PM
Need help on 3875 Rev 3 PCB placement in enclosure ransom peek Chip Amps 7 21st March 2005 09:19 PM
