high impedance load
high impedance load
Old 10th September 2011, 01:08 AM   #1
pos is offline pos  Europe
pos's Avatar
Default high impedance load
Hi
Is there any downside, expect loss in available power, to present a very high impedance load (say 64 or even 128ohms) to an amplifier?
Old 10th September 2011, 01:11 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
It should be fine.
Valve amps are more touchy about speaker impedance.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 10th September 2011, 08:26 AM   #3
pos's Avatar
Thank you!
So no hill effect on frequency response if the amplifier was "calibrated" for a given load range (4-16 ohms), or anything?
Old 10th September 2011, 09:59 AM   #4
When one plugs in headphones the circuit sometimes switches off the speaker route to leave the headphones and their dropping resistor as the only load that the amp has to supply.
That is part of the reason that Thiele Networks or Zobels are fitted to the amp output, so that they remain stable into a wide variety of load impedances.
regards Andrew T.
Old 10th September 2011, 09:40 PM   #5
pos's Avatar
Thanks a lot!
Old 11th September 2011, 02:52 PM   #6
ingenieus is offline ingenieus  South Africa
How would you go about making up a speaker with an impedance of 64 ohm or so. You could wire up a whole lot of eighy ohm drivers in series. Some sort of modern day Bose 901 perhaps...?
It's just that there is a ninth driver on the other side of the enclosure and the original was not wired in series....
Old 11th September 2011, 03:18 PM   #7
digits is offline digits
digits's Avatar
Four goodmans axiom 10's in series at 15 ohm each, good for 35 to 15k
I do suspect we are talking headphones here, if not one has the other side of the coin, how do you swing enough voltage to get any power out of 128 ohm.
Old 11th September 2011, 04:11 PM   #8
RJM1 is offline RJM1  United States
Sounds like a job for a tube.
(((320V P-P)*0.3535) ^2)/128Ω=100W
Old 11th September 2011, 06:22 PM   #9
If I may correct myself - if you want a modern Bose 901, you can just buy it:
Bose 901 Speaker System ? Home Stereo Speakers - Bose Speaker Systems
Old 11th September 2011, 08:22 PM   #10
Bose, somwone stop me quick.
some 350 enhancements over the acclaimed original.
And what are they except for injection molded for added strength?
high impedance loadHide this!Advertise here!
Plate load impedance MrCurwen Tubes / Valves 13 24th September 2010 08:29 PM
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 07:49 PM
How concerned should I be about load impedance? cdwitmer Solid State 1 18th November 2006 03:13 PM
Chip amp distortion with high impedance resistive load. Circlotron Chip Amps 3 26th January 2005 02:02 PM
Multidriver impedance load Steen Multi-Way 1 2nd August 2001 12:46 AM
Copyright ©1999-2017 diyAudio
