PCB Layout Process and Guidelines? - Page 4 - diyAudio
Old 11th September 2011, 10:46 PM   #31
Greg Erskine's Avatar
hi jkuetemann,
Here's my advise.
1. Read as many related posts as possible, all the information has be posted before, over and over.
2. Just do it and get it finished. It will never be "perfect" but learning from you own experience is invaluable.
3. Do not ask too many questions, you will only get 15 contradictory replies that will confuse the issue and prolong the project.
4. All (most) of us post information based on anecdotal evidence. Amp A sounds better than Amp B, arh... it must be because the PCB is red not green.
regards
Greg Erskine
Old 11th September 2011, 11:02 PM   #32
nigelwright7557's Avatar
Originally Posted by Greg Erskine View Post
hi jkuetemann,
My advice comes from 30 years experience of pcb design.
It also comes from 20 years of writing and improving pcb cad design software.
Error checking is absolutely vital and I have concentrated on this.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 11th September 2011, 11:50 PM   #33
hi nigelwright7557,
I tried to PM you and this reply doesn't add value to the thread, but it seems you have PM turned off.
I have read lots of your posts over the years and have great respect for your knowledge and skills, not to mention your keenness to pass on your experience. I am also envious of your software writing skills, that would be perfect, to have such control of the design process. I wasn't having a go at anyone.
Yes, error checking is absolutely vital. I won't look at posted PCBs in detail unless the schematic is also posted. IMHO, software that doesn't have forward and backward annotation is next to useless but I have seen people do the job with MS Paint but who am I to say this is the wrong approach for them.
regards
Greg Erskine
Old 12th September 2011, 12:00 AM   #34
hi nigelwright7557,
regards
According to CP my pm is on.
You can download a copy of visual c# express and start writing your own pcb software. C# is very powerful for programming and also is great for pcb graphics for pads tracks text etc
When I first started I had to write all my own graphics routines right down to plotting points, tracks, pads text etc. and that was all done in assembler writing directly to the pc screen bitmaps !
I developed my software while using it, as I found a need for a new function e.g. back annotation then I would add it.
My software is flogged to death and has around 500 users so I get to know of bugs very quickly. If anyone finds a bug then I fix it and immediately send them an update. Other companies just add it to a "to do" list for the next revision.
Old 12th September 2011, 12:48 AM   #35
Sorry to reply to myself but I fixed the PM, I had opted to only let moderators PM me.
Old 12th September 2011, 01:00 AM   #36
AKSA is offline AKSA  Australia
Pcb design is a form of industrial art with strong technical input. You learn by doing, then being coached by an experienced person. It's not easy and takes years to perfect, and even then there are always criticisms. The advice given here is excellent.
Nigel, how do you create a thermal relief pad in Protel 1.12? I realise you may not know, but it's driving me crazy and any advice gratefully received,
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 12th September 2011, 01:04 AM   #37
Hugh
Not sure about Protel but my software automatically creates a powerplane with relief for pads and tracks unless the track net is connected to the powerplane net.
Old 12th September 2011, 01:08 AM   #38
jcx is offline jcx  United States
I had good results as the designer, sitting with the contract PBC layout "jockey" - I could guide parts placement, highlight sensitive nodes, runs, voice concerns on power distribution - but he could run rings around me in implementaiton choices, running the sw
when on my own rats nest with rubber banding, starting with absolute constraints on power distribution/seperation from sensitive circuits - a willingness to start over when finding myself "cornered" seem most valuable
don't forget that as a hobbyist jumpers, above board bus bars, dropping soldered input, output or even power (twisted pairs) into the middle of the board can be practical where mass manufacture may prevent such "shortcuts"
Old 12th September 2011, 12:00 PM   #39
jkuetemann's Avatar
Originally Posted by jcx View Post
Don't forget that as a hobbyist jumpers, above board bus bars, dropping soldered input, output or even power (twisted pairs) into the middle of the board can be practical where mass manufacture may prevent such "shortcuts"
Yes, I must remember these things as well. I'm planning on constructing my boards at home, so combinations of these techniques are allowable. DIY has a certain flexibility in implementation you don't get in mass manufacture. I appreciate the input that has been provided. I will also continue to 'study' some of the more popular / successful projects here to see how the more experienced have chosen to approach the task.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 10th October 2012, 02:44 PM   #40
jkuetemann's Avatar
First off, sorry about reviving an old thread of mine but since the content is relevant I figured better to continue with this one than start anew.
I'd like some peer review related to the PCB layouts more so than the schematic. I'm looking for gross layout problems or outright errors that I may not have seen. I am also interested in the finer points as well. Any constructive comments or criticism welcome.
PCB Manufacturing Process with Eagle PCB Algar_emi Parts 1 3rd June 2016 10:48 PM
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
About PCB layout gaetan8888 Solid State 14 11th January 2008 04:11 AM
Amplifier PCB Layout Guidelines? ron.eddy Parts 19 18th December 2005 05:17 PM
PCB design guidelines mangrovejack Parts 3 10th July 2005 11:10 AM
Copyright 1999-2017 diyAudio
