I am looking for all solid state class AB amplifier with very very good sound/performance with about 50W into 8 ohms of power. I have already built LM3875 chipamp (not a bad sound for that little money) and 25W class A tube/mosfet hybrid without GNFB, which is not suited for my taste of music which is mainly rock/metal. I was thinking about Leach amplifier or DX Blame amplifier. But Leach looks to be very powerfull and I do not know if DX Blame is one of the best amps or just ordinary one. Thank you. |
#2 |
I have the same taste in music, its not easy to choose a amp for it. I have found that the fast amps sound the best for this type music, stay away when they say the amp sounds tubey, as you have out for yourself. The best Ive heard as a diy is the stochino amp, not simple to build and I only recommend for advanced users, I also give credit to the optimos amp which is also very good and powerful.
As a simpler project I would recommend the Symasym amp, it has a powerful bass and sweet trebles, blame type amps are a bit bass light for this type of music. |
#3 |
Symasym looks good. It seems to have all attributes I am searching for.
Thank you! |
#4 |
So I have my Symasym built for about half a year now and it is so far the best amp for me. Sounds better to my ears than Pass F5. Is there some DIY project which sounds better than Symasym? Maybe Leach? I am fine with 50W into 8 Ohms. Please no class A heaters. Thanks. |
#5 |
Roender's FC 100 shares some of the symasym topology.
There are soon to be PCBs for a clone of Roender's amp.
regards Andrew T. |
#6 | |
#7 |
Speakers are 8 ohm bookshelf Focal Chorus 807V. I have F5 with IRF and simple mosfet regulated power supply. Symasym has more detail, better soundstage and is overall more cleaner and accurate without generating lots of class a heat.
#8 |
I think dadod's thread "ThermalTrak+TMC amp" has done a good job at combining several of the important topics from Bob Cordell's recent amplifier book into a design that simulates well. See post #48,
DADO-TT-triple-bufferedVAS.pdf 1) Triple T output stage 2) TMC nested feedback 3) improved cascode circuits for front-end diff stage 4) JFET input transistors 5) optional regulated power supplies Since speakers make a larger difference in sound quality than amps. Have you considered designing a multi-amp speaker with analog or digital electronic crossover? You could put multiple amps into one chassis, plus any necessary Xover circuits. |
#9 | |
#10 | |
All the trouble I've ever been in started out as fun...... |
| Please recommend a tube DAC to build. | JayH3 | Digital Source | 1 | 26th May 2008 01:50 AM |
| Please recommend me an amplifier design. | JayH3 | Tubes / Valves | 47 | 11th April 2008 08:00 PM |
| Pls recommend a power amp to build? | pengboon | Tubes / Valves | 39 | 17th August 2006 04:53 AM |
| Recommend a floorstanding 2-way to build? | happyb | Multi-Way | 6 | 12th March 2006 03:39 PM |
| recommend me an amp to build | maxw | Solid State | 14 | 15th September 2004 08:20 AM |
| Page generated in 0.10265 seconds (84.63% PHP - 15.37% MySQL) with 11 queries |
