Hello All,
I have this little Nikko Amp(A-300D) which I am in love with.. Its my bedroom system and I acquired it from a gentleman here in Singapore few years ago It still works flawlessly... Today I thought may be I should recap it, and use with a pair of Altec Lansing Corona 893B. So I opened it up again to take a closer look Lo and behold... It seemed like someone has already changed few caps Or at least I can see wires with soldering iron burn-marks Seems like someone as dexterous as me was at work Things like power supply filter caps seem to have been replaced. Currently it has Elna 2200F/35V Electrolytic caps And I can also see Korean brand Samwha electrolytic caps as well I dont know how good they are but that looks like a replacement job too The main arguments for the recapping are; there are less than 24 caps on the board in total and the PCB is a simple layout single layered design with abundant use of wire jumpers to complete the routes. All the electrolytic caps are nicely indicated with polarity/orientation on the PCB(with the symbol as well as + marks) And All the values can be read. But considering my dexterity when it comes to soldering, I am still a little hesitant to embark upon a changeem all mission Only if it is worth the risk So is there any easier way to identify the coupling caps, than to manually track the lines? Better if someone has the schematic (which I am really not very hopeful of) |
#2 |
Attached are the pics of the board… Your suggestions please…
![]() ![]() ![]() ![]() ![]() ![]() Info in Japanese… NIKKO vCAvA-300D̎dl jbR[/Kdq |
#3 | |
Now, I don't see anything wrong with that, but only if you like the smell of resin. The best technical result I can think of is that it still works as good as it does now after you'r finished (on offence) |
#4 | |
#5 |
(on offence = no offence)
Ok, now I understand. I feel the problems with aging capacitors and the benefits of changing them are much exaggerated, but this piece might give you some infomation ELNA AMERICA, INC. To find the coupling-caps, without a schematic, I think tracking the traces is the only option. |
#6 |
I went ahead and ordered all caps.. All 32(yeah I missed counting few earlier) of them!
An unusual find... Spend 20mts earlier today and I found that there is a 3300F/50V cap as well... I tried to trace the tracks to see where it is powering, it seems to be supplying a Single power supply which is marked as B+ and those 1N4007 type diodes you see in the below picture( see in half-bridge configuration) seems to be the rectifier section for this cap... Having said that I didn't get time to find the rectifier section for the dual rail supply with twin 2200F/35 caps. the bigger diodes in the picture, I am not sure are part of oa full wave bridge setup, but then i couldnt find the remaining two diodes... neither I could continuity trace them to any of the 2200F caps... May be I need more time those 20mts were not good enough... thats what happens when there is no schematic Last edited by Ronj; 8th September 2011 at 03:59 PM. |
#7 |
#8 |
You might have to take caps in higher voltage rateings to get the same pin pitch as modern caps which tend to be much smaller for a comparable capacitance.
#9 |
Today I started changing the caps and I am half-way through... I did find a few dry solder joints also along the way....
Then I saw that two diodes are kind of glued to the heatsink per channel... and one of them got unstuck... I don't have any idea what kind of glue it is.. I have never seen something like this before... Can any one here please help me out what compound is used to glue diodes to heat-sink? It looks like rust colored now, as there is some rust also on the heat-sink where it was stuck... below are the pictures... please look at the red oval's i marked to identify them... Any suggestion on what to use to stuck them back on to heat-sink is really really appreciated! |
#10 |
| SKA Audio 300D boards: Essentially a Kit | deicide67 | Swap Meet | 1 | 13th April 2010 07:18 PM |
| Greg Ball SKA 300D amplifier | nycavsr2000 | Swap Meet | 4 | 1st February 2010 06:12 AM |
| recapping | peace brainerd | Everything Else | 3 | 20th February 2006 07:26 PM |
| Recapping optimization? | kyrochan | Solid State | 0 | 26th October 2005 03:16 PM |
| Recapping questions | MikeA57 | Solid State | 1 | 24th March 2005 08:57 PM |
| Page generated in 0.12622 seconds (78.07% PHP - 21.93% MySQL) with 10 queries |
