L12-2   CFP Output amp  120W*2 8R
Old 5th April 2013, 04:45 AM   #41
ivanlukic is offline ivanlukic  Serbia
It is difficult to see from the pic, but drivers and VAS tranies seem to be 2SB649/2SD669. These are good parts, and I would keep them. Not so low Cob as some, but still good overall.
Old 5th April 2013, 06:01 AM   #42
sajti is offline sajti  Hungary
Originally Posted by Evenharmonics View Post
For 1815, I found this http://www.mouser.com/ds/2/149/KSC1815-59515.pdf Spec is just about the same except for the middle lead is base instead of collector. I suppose I can just bend it to fit the board.
Try KSC1845 instead of 1815
Sajti
Old 5th April 2013, 07:34 AM   #43
Ian Finch is offline Ian Finch  Australia
I thought there was something odd about that datasheet. look at this, also from Fairchild......KSC1815 Pinouts , KSC1815 Pin out,KSC1815 pin diagram
Also, I should have posted the complement to 2SA970, ie. 2SC2240 and that is almost the same as satji's suggestion, KSC1845. These are all listed in Greg's chart, #39
If only I had listened....
Old 5th April 2013, 07:41 AM   #44
The 2SC2240 2SA970 is not manufactured any more, unfortunately. Only smd version is available. It's not easy to get original Toshiba version now.
KSC1845/KSA992 is available from Mouser for peanuts. I have ordered 1000pcs each.
Sajti
Old 5th April 2013, 07:50 AM   #45
Thanks, sajti. I checked this earlier this year and the "not suitable for new manufacture" was still showing. Well, it seems to happen to every good thru-hole part.
Old 5th April 2013, 07:59 AM   #46
Unfortunately I was the bad guy, who ordered the whole 2SC3423/2SA1360 stock from Mouser (300pcs each), and get the last stock of 2240/970 from Newark. It looks, that we have to make our own stock for the future, to keep our hobby up, and running...
Sajti
Old 5th April 2013, 02:58 PM   #47
Evenharmonics is offline Evenharmonics  United States
I noticed that after posting my finding yesterday. I was going to check the pinouts with DMM before installing anyway.
Thanks Ian and sajti.
Old 17th April 2013, 04:46 AM   #48
Bump.
Also replaced 5401 and 1815. Now DC offset is 2 mV. It was a cheap (they are 10 - 15 cents each) and fun learning experience.
Old 19th April 2013, 08:24 PM   #49
Good, I honestly thought you would have more difficulty getting a match there. Was it the current mirror pair that made the difference?
Old 19th April 2013, 11:54 PM   #50
It was 5401 pair (Q15 & Q16) that made the main difference. When I replaced 1815 pair (Q11 & Q13, Q17 & Q19), DC offset still remained at 14 mV.
So here's the DC offset track record:
1) -24 mV out of the box stock.
2) 15 mV when I replaced 1015 pair (Q6 & Q8).
3) 14 mV when I replaced 1815 pair (Q11 & Q13, Q17 & Q19)
4) 2 mV when I replaced 5401 pair (Q15 & Q16)
L12-2   CFP Output amp  120W*2 8RHide this!Advertise here!
BTL 800W 8R OUTPUT L15 ljm_ljm Solid State 20 12th May 2016 05:06 PM
CFP output stage adding more output transistors diy didi Solid State 2 2nd February 2013 06:15 PM
L12 120w amplifier kit on eBay....anyone familiar with it? jmillerdoc Solid State 0 13th March 2012 01:58 AM
A trashed currentfeedback amp from 2003 with CFP output.... sonnya Solid State 0 23rd October 2009 06:31 AM
Output from Shiva with 120w? nrgy Subwoofers 2 12th November 2004 12:18 PM
