Old 6th September 2011, 10:58 AM   #1
Default Rotel 820AX problem - any known issues?
Hi
I'm after some advice on a Rotel 820AX that I've just bought. Ebay, excellent condition but not tested - I know, I should know better.
Anyway, turning it on and nothing until the volume was turned fully up when I can hear quiet and 'noisy' music. Same through all inputs, and both sets of speaker outputs.
I've opened it up and there is no sign of damage to any components. No obvious leaks from capacitors, no obviously blown transistors or resistors, no brown patches anywhere.
It is however quite dusty and there is the remains of a couple of smallish beetles.
One fuse has blown. (F601)
I'm going to replace the fuse and see what happens, but I thought I'd ask the question, are there any well known issues with this amp?
I'm assuming that the fact that I hear anything is good, and it is likely that the fuse is the supply to the power amp part of the circuit. I'm going to look for a service manual and see if I can find circuit diagrams and schematics.
Suggestions welcome.
thanks
Mark
Old 6th September 2011, 11:58 AM   #2
homemodder's Avatar
Originally Posted by rotelmark View Post
Hi
thanks
Mark
There arent any issues with these amps, Rotels are very reliable but dont take certain abuses well. The blown fuse will tell you that something has gone wrong. I wouldnt just replace the fuse and switch it on if I were you, you may cause further damage if something did go wrong. Test the output transistors and their drivers first, actually Id test all transistors first to make sure they arent blown before powering on, there arent that many. Also check the powersupply rectifier. Due to its age it would be wise to exchange the power supply caps.
Old 6th September 2011, 02:03 PM   #3
Thanks for the comments.
I was hoping that the dust/insects might be responsible for a short. But I'll get some new fuses ordered and have a look at the components you suggest.
thanks
Mark
Rotel RCD-971 Issues CR500 Digital Source 25 14th February 2011 09:47 PM
Problem with Rotel RB850 rmsmax Solid State 21 27th January 2009 12:42 AM
Rotel amp problem Rotellian Solid State 14 6th February 2006 05:32 PM
Rotel 855 problem Mikelo Digital Source 3 11th January 2005 03:47 PM
Page generated in 0.07763 seconds (75.43% PHP - 24.57% MySQL) with 10 queries
