Hello to everybody!
I am kindly asking you for a schematic and PCB for a 10-20 watt class A amplifier.I know there are a set of rules in designing the PCB, but I haven't read them yet(actually, I'm a mechanics engineer and I'm very fond of audio). I asked a coleague from work to design the PCB for me ( an electronics engineer) but he's not in the audio stuff and I don't think he followed the rules. I will be forever greatfull and I will keep you up to date with the construction. Best wishes, |
#2 |
There are some amplifier designs you might like here:
The Class-A Amplifier Site and all the pcb's you need here: http://www.kk-pcb.com/amps.html don't forget to order a Large heatsink !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 |
Thank you very much Bigun! I know the schematics from JLH but it's kind of hard to order a PCB from Bucharest, that's why I wanted a schematic PCB for DIY purpose.Has anyone made a PCB for JLH class A amp?
#4 |
Hi mselagea,
Could you please mail me at selim_ardali at yahoo dot com? Maybe I can help. Cheers Selim |
#5 |
Try here JLH-2005 – NOTES
#6 |
To be honest, I suspect that you could get away without using a pcb for the JLH 10W amp. It's a classic amp with an excellent reputation. I believe JLH himself built it on a piece of stripboard.
#7 |
My vote goes to the little 10W mini aleph.
#8 |
Thank you very much everyone.I will talk to my coleague tomorrow regarding the links you have sent me.I will keep you updated with the results.
#9 |
There are JLH pcb's on Ebay that you might have a look at; also kits with components for the same.
Check out Jims Audio ebay shop. |
| Power transistor for class A amp | MrJimBeam | Parts | 3 | 9th January 2010 05:30 PM |
| Phono Pre-amp/Class-T Power Amp | lazaroff | Chip Amps | 0 | 23rd August 2009 01:32 AM |
| Class H Power Amp. | EMX_125 | Solid State | 0 | 5th July 2008 08:54 AM |
| Valve Pre Amp & Class D Power Amp | Puffin | Tubes / Valves | 7 | 16th June 2006 04:41 PM |
| Page generated in 0.07998 seconds (84.41% PHP - 15.59% MySQL) with 10 queries |
