I was given an working but disabled Adcom GFA-535 by a friend with missing output devices. He said that he needed those parts(2sd1047 & 2sb817) for another project he was working on. After doing some research and looking through parts I had available I was able to come up with some 2sc5200 and 2sa1943 Toshiba devices from an old pa amp I had laying around. I asked my friend if those devices were suitable to use in the 535 and said it should be fine. Before doing this, I wanted to check here and see if it was indeed fine to use those or does something need to be changed or adjusted to accommodate these new transistors besides the fact that my replacements are slightly larger.
Thanks! Ardvaark |
#2 |
Good, no objections. I'll solder them in tonight.
Ardvaark |
#3 |
The one and only
Should be fine, which you probably know by now.
#4 |
| Adcom GFA 535 power switch sticking | cbrown0034 | Solid State | 8 | 15th February 2010 03:30 PM |
| Adcom GFA-535 Settings | Ardvaark | Solid State | 2 | 16th August 2009 08:10 PM |
| Adcom GFA 535 Clicking on Power Up and Down | YammerBoy | Solid State | 1 | 14th June 2009 10:12 PM |
| Adcom GFA-535... Pics... is THIS Stock?? | 777funk | Pass Labs | 17 | 19th May 2009 06:43 PM |
| FS: Adcom GFA-535 | sdstarnes | Swap Meet | 3 | 12th February 2008 02:43 AM |
| Page generated in 0.07413 seconds (73.46% PHP - 26.54% MySQL) with 10 queries |
