diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Technics SU-V40 (http://www.diyaudio.com/forums/solid-state/195936-technics-su-v40.html)
jtubio1 4th September 2011 07:05 PM
Technics SU-V40
Dear friends: I have an old Technics SU-V40 Class AA, recovery from dump, based on SVI4003 power amp IC plus 2SC3298 / 2SA1306 power transistors.
It does not work and I want to fix. Anybody has the manual service / repair book?. I am reading similar threads and I have a question on the SVI replacement: Is SVI same that
ThorstenL 4th September 2011 07:45 PM
Originally Posted by jtubio1 (Post 2697594)
Dear friends: I have an old Technics SU-V40 Class AA, recovery from dump, based on SVI4003 power amp IC plus 2SC3298 / 2SA1306 power transistors. It does not work and I want to fix.
Hint.
Gut it, build an LM3875TF based gainclone in the chassis using the transformer, heatsink etc.
It will sound better and not cost much.
Ciao T
jtubio1 5th September 2011 11:09 PM
SVI4003 Technics IC power amplifier
Hi all, In the before reply I want to do this answer: Is same SVI4003 that STK4003?
Thanks in advance, Jorge
jaycee 6th September 2011 07:57 AM
No. The STK4003 is a complete power amp on a chip. The SVI4003 is just the small-signal stages that uses external power transistors. If I remember correctly it was made specifically for Technics. The SVI was the weak point which often overheated and failed.
A replacement will be difficult to get.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
