Old 2nd September 2011, 07:47 AM   #1
panson_hk's Avatar
Default Hall-effect current sensor for output stage over-current protection
I am considering to use a hall-effect current sensor such as ACS-712 (http://www.allegromicro.com/en/Produ.../0712/0712.pdf) to protect amplifier output stage. The resistance of the copper conductive path of ACS712 is just 1.2 mR which is effective zero resistance in the intended application. It is also electrically isolated from other part of the chip. The output analog signal can be used to drive a relay circuit or sampled by ADC of an MCU.
Since the conductive path is just a piece of copper, it should not introduce any distortion. Although the chip employes chopper stabilization technique, the electrically isolated path should not be picking up any interference. Well, it might via capacitive or inductive paths.
Any comment?
Old 2nd September 2011, 05:21 PM   #2
cbdb is offline cbdb  Canada
Looks like a great idea.
But probably no worse than any other technique.
Old 2nd September 2011, 05:57 PM   #3
Lazy Cat's Avatar
More than ten years ago I did similar current sense-protection, adjustable to any current-trigger level as needed. It works perfectly till these days.
Old 2nd September 2011, 08:03 PM   #4
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
I posted one a while back, Still in daily use
hall effect dc speaker protection
Old 6th September 2011, 03:07 PM   #5
panson_hk's Avatar
Lazy Cat and Spiny,
Yes, I visited your thread.
I plan do all the things in an MCU which samples Vce, temperature, etc. Transistor SOA parameters can be input to the firmware. Temperature data can be used for derating.
Hall Effect DC Speaker protection Spiny Everything Else 2 9th January 2010 04:55 PM
Current Sensor based on OpAmp mahmood Power Supplies 4 26th September 2008 05:08 PM
UcD output stage current sensing zilog Class D 20 6th November 2006 08:04 AM
Floating current source in cascoded output stage rtarbell Pass Labs 0 7th April 2006 01:46 AM
Over-current protection in Audio IC Output Buffers ppl Solid State 1 21st October 2003 06:35 AM
Page generated in 0.08398 seconds (70.80% PHP - 29.20% MySQL) with 11 queries
