If you have 2 pairs of 16A, 250W TO-3 Lateral FET's with a SOA curve showing a maximum DC current of around 6A at 42V Drain-source what would a reasonable current limit be set to?
There is no 100ms or 10ms SOA plot for the Semelab BUZ line of FETs that I'm planning to use. I know they are Laterals so they have their own "built in" current limiter due to their negative temp co but in my case I am using flying catch diodes to limit the maximum Vgs. Which of cource means that I also have a current limit. Double the amount of flying catch didoes in the diode string from 1 to 2 which gives me a current limit of around 12-13A so that is very close to their specified DC current in the SOA plot. However, for music would it not be reasonable to set the current limit a little higher, say 20A instead? Just needs another pair of diodes and I'm at 20A. 20A with a music signal should be well within the limit of 2 pairs of 16A, 250W, TO-3 Laterals. Any thoughts and/or suggestions? Last edited by Neutrality; 30th August 2011 at 08:51 PM. |
#2 |
Most laterals are about 1A per volt of gate voltage. Clamp the gates at 10V and use a thermal cut-out at 85°C, that should be enough.
Candidates for the Darwin Award should not read this author. |
| Power supply current limit for testing | kubeek | Solid State | 1 | 12th February 2009 09:57 AM |
| ALW Regulator Current Limit? | fmak | Solid State | 7 | 27th January 2006 08:38 AM |
| Which NTC to limit inrush current | Mlaen | Solid State | 24 | 10th February 2005 12:52 AM |
| LED current limit resistor value calculator | tomchaoda | Parts | 0 | 21st September 2004 04:24 PM |
| Current limit of EL84 grid? | G | Tubes / Valves | 10 | 22nd February 2003 07:08 PM |
| Page generated in 0.07015 seconds (67.43% PHP - 32.57% MySQL) with 10 queries |
