Old 30th August 2011, 01:03 PM   #1
Default Jitter or phase noise in LTSPice
Is it possible to simulate the jitter of an oscillator with LTSpice ? If not what software can do that (preferably free) ?
If it is possible, an explanation of how to do it would be much appreciated. Also, please explain how to get the numerical values from the simulation results (voltages / currents).
Old 30th August 2011, 01:35 PM   #2
Elvee is offline Elvee  Belgium
Something like that?
You can change the jitter profile by inserting any mathematical expression into B1's value.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 30th August 2011, 01:41 PM   #3
What I want to do is create the schematics of an oscillator in LTSpice, simulate it and compute its jitter / phase noise.
Old 30th August 2011, 04:48 PM   #4
It is possible to reproduce any measurement you make in the real world in simulation: the FFT tool is the equivalent of a spectrum analyzer, and by measuring and integrating the power vs carrier offset, you could derive the phase noise.
You have to configure carefully the simulation and fft parameters to avoid measuring sampling artefacts.
Since this is not an audio-related topic, you should post your question on the yahoo LTspice group, this will maximize your chances of getting pertinent answers.
Old 30th August 2011, 05:38 PM   #5
jcx is online now jcx  United States
high Q oscillators are painful to sim due to the huge number of complete cycles of oscillation you need to sim, each at good resolution for the phenomena you want to see
the other problem is noise modeling in a .TRAN analysis isn't "native" - you have to add the component noise as additional models with the statisitics you expect
better oscillator circuits have low enough electronic noise that thermal drift, microphonics from external vibration become important - you would need to add even more "custom" sources to the standard Spice models to see these effects in a sim
Old 30th August 2011, 06:30 PM   #6
Tanks, do you have a link to a more detailed description of this method ?
Old 30th August 2011, 06:33 PM   #7
I want to start by modeling a simple RC oscillator where I would only need a reasonable amount of cycles to get observable effects.
Do you have links to papers, books etc. that explain the process and maybe give examples ?
Old 30th August 2011, 07:24 PM   #8
Just enter the terms I used in google:
"spectrum analyzer" and by jitter measurement and integrating the power carrier offset you could derive the phase noise - Google Search
But the devil is in the details, and implementing any method properly and efficiently (timewise) in LTspice requires care and attention, as jcx reminded you, that's why I recommended you ask the question on the specialized LTspice forum.
Old 30th August 2011, 07:55 PM   #9
Make me think one I heard quite a few times as a student: "If you want an oscillator, design an amplifier! And vice versa, of course."
I have occasionally come up with a good oscillator, when I followed the above truism.
Sorry, this doesn't answer the question. Just wanted to share it. The Yahoo group should come up with better advice than this.
Old 30th August 2011, 11:18 PM   #10
Thanks, I'll take a look at the links and try the LTSpice forum.
Of course I am also interested in the method to do that in a typical SPICE software not just LTSpice.
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Article on clocks, jitter, phase noise........ Jocko Homo Digital Source 2 24th December 2005 10:19 PM
jitter and noise performance of 74xx AC and VHC series? patwen Digital Source 2 22nd November 2004 12:31 PM
As promised.......the Phase Noise Files..... Jocko Homo Digital Source 27 5th April 2003 10:39 PM
Page generated in 0.09636 seconds (84.78% PHP - 15.22% MySQL) with 11 queries
