Old 30th August 2011, 08:56 AM   #1
Hayden is offline Hayden  Australia
Default how can the wattage be?
Am I correct in saying an amp can not be 1000watts when the power consumption on the back of the device says 250w at 50hz?
I have stereo that's 3500watts and I am running it of an Australian power socket which is 240v 10amp = 2400watts
can it really put out more than it is drawing? or is it totally different thing?
Cheers
Old 30th August 2011, 09:11 AM   #2
just another
wintermute's Avatar
It's most likely a PMPO rating (Peak Music Power Output). A completely useless (except for marketing purposes) measure
RMS rating is what you really need to look for. It is a theoretical figure that the amp can possibly produce on a transient for a split second.
If the consumption figure is 250W then you are probably looking at most 100W per channel RMS and most probably lower.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 30th August 2011, 09:18 AM   #3
AndrewT is online now AndrewT  Scotland
Part of the game of the consumer is learning to read the literature so that one buys the goods one needs.
If can be a food mixer, or a radio, or a cordless power drill, or a packet of low fat XXXXX, or an electronic component.
regards Andrew T.
Old 30th August 2011, 09:33 AM   #4
sofaspud's Avatar
The power out cannot exceed the power in. So, you are correct.
I don't even trust RMS ratings unless I know the manufacturer to be reputable and thoroughly honest about their equipment specs.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 30th August 2011, 09:43 AM   #5
learn to read the supporting literature.
100W+100W into 8r0+8r0, both channels driven continuously by 1kHz sinewave with a maximum distortion of 0.1% to stand xxx, is completely to unambiguous.
It is also impossible to get more of this output power continuously, than what is put in continuously.
Change the spec to:
127W+127W into 8r0+8r0, 1kHz gated sinewave, 5% duty factor, to standard xyy, is equally valid.
Similarly:
317W+317W into 8r0 peak instantaneous power to standard zyx is quite possible.
The transformer for all these specifications is likely to be somewhere between 200VA and 500VA.
The labeled power rating could be any number the manufacturer cares to put on the device that they think gives guidance to potential users and operators.
regards Andrew T.
Old 30th August 2011, 09:54 AM   #6
jogi59 is online now jogi59  Germany
No
Many manufacturers measure the power consumption with 1/8 output power. Then 250w seems reasonable.
If you listen to music and not sine waves, it is no problem to get peaks of 3500w out of your 2400w socket.
Old 30th August 2011, 10:12 AM   #7
just another
wintermute's Avatar
This should have read :
RMS rating is what you really need to look for. PMPO is a theoretical figure that the amp can possibly produce on a transient for a split second.
Tony.
Some of my photos
Old 30th August 2011, 10:17 AM   #8
Mooly's Avatar
Cheers
Watt are the products in question... can you name names ?
A simulation free zone. Design it, build it, test it.
Old 30th August 2011, 10:21 AM   #9
sofaspud's Avatar
250w may seem reasonable, but isn't that then 1/4, not 1/8?
PS thanks for that clarification, wintermute. You really had me confused for a moment.
Old 30th August 2011, 10:24 AM   #10
I could probably make an amplifier that runs off some AA batteries that could deliver a kilowatt for a fraction of a second. But I don't think I could honestly advertise it as a 1kW amplifier.
transformer wattage aleks990 Parts 8 22nd February 2011 12:42 AM
Does preamp wattage effect power amps wattage? JonnySwitchblade Solid State 7 4th July 2007 03:18 AM
wattage of an speker JhonDoe Parts 3 27th January 2004 01:50 PM
Speaker wattage[rms] versus amp wattage[rms] Bull Multi-Way 5 9th November 2002 05:55 AM
Page generated in 0.10383 seconds (80.00% PHP - 20.00% MySQL) with 10 queries
