Looking at doing a maintenance replacement of the electrolytic capacitors on this small head amp. It is over 30 years old, and has gone unused for several years. There are 11 Illinois Capacitor caps on (and under) the board. See pic below of what the board looks like. Here is a circuit drawing (graciously provided by another forum poster, xjwmcx).
PPA-1h Circuit Drawing No idea on the specs of these 30 year old caps, but current general purpose IC caps are approximately as follows: IC, 220 uF, -10/+50%, 10 V, ESR 1.5 ohms, DF 0.2, Ripple 250 mA Here are three choices I've considered for replacement, considering physical size limitation. Also selected 270 uF +/- 20% over 220 uF, for tighter control and better match to original if available. Elna, RFS, 220 uF, +/- 20%, 25V, ESR ??, Ripple 505 mA, Tan 0.1, $1.25 (CDN) Panasonic, EEU-FR, 270 uF, +/- 20%, 50 V, ESR 0.023 ohm, Ripple 1,890 mA, Tan 0.1, $0.84 Nichicon, PL Solid Polymer, 270 uF, +/- 20%, 10 V, ESR 0.008 ohm, Ripple 4,900 mA, Tan 0.08, $0.87 Thoughts on the best choice of these, or another choice I've overlooked? Elna seems to get "golden ears" recommendations, but the specs don't seem to measure up to the other two. The solid polymer electrolytic seems to be the clear winner based on specs. Any reason not to use them in an audio circuit? The board also has 0.1 uF film bypass caps. With a 1.5 ohm ESR they may have helped a little, but seem almost worthless with a 0.008 ohm ESR. I suspect they are polyethylene, but may just leave them, or replace them with a 0.46 uF metalized polypropylene just to keep the "look and sound mystic" intact. All thoughts appreciated.
| B&W Capacitor Replacement- Need Help | Ckyguy68 | Multi-Way | 18 | 8th February 2011 03:28 AM |
| opinions on ideal replacement for 6L6GC and 12AX7 in valve amp? | mondogenerator | Instruments and Amps | 3 | 21st December 2009 12:07 AM |
| Capacitor Replacement in a Guitar Amp | betelgeuse | Parts | 11 | 7th July 2009 05:36 PM |
| 2 SteinMusic 1H/30-Ohm chokes for Phono Pre-Amp | markjohn2000 | Analogue Source | 0 | 27th January 2004 05:12 AM |
| Capacitor Replacement on Spectro Amp | ralph-bway | Solid State | 2 | 17th October 2003 03:52 AM |
| Page generated in 0.06067 seconds (80.32% PHP - 19.68% MySQL) with 10 queries |
