Old 25th August 2011, 08:29 AM   #1
Nrik is offline Nrik  Denmark
Default Nakamichi PA5E MK II service manual / schematic
Hi
Does anyone have this ?
I can easily find PA5e mkI and PA7, but not PA5e MKII.
There are two trimmers on each channel ( only one in MKI)... wich on is idle current/Bias, and what does the other do ? (DC-offset? - or bias for the extra 4 transistor-pairs?)
STOP - Hammertime!
Old 1st September 2011, 06:57 PM   #2
No one ?
STOP - Hammertime!
Old 16th September 2011, 08:05 AM   #3
Okay so thanx for nothing guys no it's okay.
I never found any servicemanual, schematic or adjustment procedure, so I had to reverse engineer the whole shabang and calculate decent standing currents myself.
Note the schematic and adjustments are somewhat different for the other models PA5, PA7 and PA7mkII, so please use this only with PA5EII and maybe the non-european version PA5 mkII.
So I will here share my findings in case someone else will need to adjust his/hers Namaichi PA5EII.
This procedure gives approximately 10mA through drivers Q114+Q115, 115mA through each output-transistor Q116-Q119 and finally 40mA through each CFP-secondstage output-transistor Q120-Q127.
I read about some people who where bumping up the current to gain more class A sound. Eventhough the heatsinks seems to be able to handle it, I will strongly recommend you to keep the original settings. The CFP/sziklai output stage is superstable and seems in perfect symmetry at these settings. But if mess with it, bad things could happen.
Here is how to do it.
STOP - Hammertime!
Old 16th September 2011, 08:21 AM   #4
sakis is offline sakis  Greece
sakis's Avatar
be nice to people here ...most of the times are very helpfull .... your post has 139 views including mine ...that also means that i took a few minutes to check my resources and had the same results with you(138 other people did the same !!! ) ...seems that documentation for your amp is very hard to get .
your procedure is correct and the information you provided is the best so far ...t5hank you for that
kind regards
sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th September 2011, 03:15 AM   #5
thaumaturge's Avatar
Best I can offer other than basic specs if needed.
Doc
http://i1112.photobucket.com/albums/...doc/NakPA7.jpg
Oops... not much help. But since I set up the link I'll leave it.
Ne timeas a facie mulierum ea ignorare
Old 18th December 2011, 02:50 PM   #6
i adjust my PA5E II with your informations and sounds like good but i think the temperature is to slow. Can it be? I read the temperature on heatsinks must be 50 degrees.
best regards
chris
Old 18th December 2011, 06:33 PM   #7
slow or low ?
Don't mind the temperature - it doesn't need to be anything specific, and if you play some music with moderate volume the temperature will increase. The temperature is a biproduct of the standing current, and this is the important parameter.
If you have the indicated voltages +50%/-30% at the testpoints, then your amp is working as it should.
STOP - Hammertime!
Old 18th December 2011, 10:35 PM   #8
oh sorry i mean low and not slow...
ok then it´s all good and the amp is working perfect.
thanks
Rotel RC 970 BX MK II - Service Manual bender7 Analog Line Level 3 27th June 2011 07:29 PM
Nakamichi service manual/schematic gain-wire Analogue Source 0 23rd March 2009 01:53 AM
Nakamichi PA-7A II Service Manual ZigmundRat Solid State 9 3rd June 2008 09:42 PM
Marantz CD75 mk II service manual plz TJ Digital Source 3 21st February 2007 06:05 PM
DACMagic II Schematic/Service Manual spikeymikey Digital Source 4 13th December 2006 04:40 PM
Page generated in 0.09702 seconds (77.00% PHP - 23.00% MySQL) with 11 queries
