I have tried circuit2 for 3" VC compression driver assuming it to be 50W.
But 2N 3055 become s too hot. it is 15A device.
Can i substitute it with TIP 35 which is 25A device ?
Or replacing the transistors with Mosfet will be better?
Any other suggestion also ok.
2.1A, 12.8V, S8, SC bayonet base.
In the USA the 1156 can be found at most Gas-and-Go type stores.
#1156 MINIATURE BULB BA15S BASE, S8 SC BAY 12.8V 2.1A 32CP, 1156, #1156, #1156 BULB, #1156 LAMP, #1156 MINIATURE LAMP, #1156 INDICATOR, EIKO# 40190,BIRNE,BOMBILLA,AMPOULE,BULBO, UPC#014271022104
