I've got a Crown CE2000A that worked the last time I hooked it up and now it doesn't. The power lights come on like normal and the signal light comes on when something is plugged in but it doesn't output anything. Also the fan doesn't come on. Help me out guys, I borrowed it from a friend and I don't want to have to replace it.
#2 |
Free Schematics Schematic Download 89-1458
First step is look on back and check the mode switch. Next the fault indication. From the blurb sheet the amp looks pretty impervious to ID 10T errors. Doc
Ne timeas a facie mulierum ea ignorare Last edited by thaumaturge; 25th August 2011 at 03:31 AM. |
#3 |
Thanks for the schematic. Any idea where to start?
#4 |
Sorry, didn't see the post before. What should the mode be on?
#5 |
Mode is on "Stereo" which I believe is correct and sensitivity is set to "1.4v" and those are the only two toggle switches that are available. The fault lights do not turn on for either channel.
#6 |
P.S. I opened it up and didn't see anything fried so I'm thinking it very well could be an ID-10T error.
| New (old) Friends | porkchop61 | Tubes / Valves | 9 | 12th October 2009 02:43 AM |
| new LM3886 pcb layout i need comments and suggestions please help me friends>>> | digitaldiy | Chip Amps | 5 | 20th March 2005 05:16 PM |
| Good by and so long and farewell to you all friends an no good friends too! | destroyer X | The Lounge | 28 | 13th June 2004 09:12 PM |
| Page generated in 0.07839 seconds (70.29% PHP - 29.71% MySQL) with 10 queries |
