quick question
I'm working on an sae 2200 I found in a thrift shop. The output transistors were bad for one channel, but I figured I would just replace all of them. However, in my haste I didn't mark down the order that they were in (NPN PNP NPN PNP) or whatever. I would rather not trace the circuits myself so if anyone has this information I would be very appreciative.
Joe
Joe
Has anyone had issues using MJ21193/94 in place of the MJ15024/25 recommended?
The specs are ALMOST identical except for Collector cutoff current, which is significantly lower on the newer OnSemi part. Mouser doesn't have the MJ15024/25 parts in stock, so I am considering alternative parts.
