Old 23rd August 2011, 09:12 PM   #1
Default capacitor upgrade for Focal 2.150 amplifier
hi, i have a pair of focal 2.150 car amplifiers, which are 150 ohms into 8 ohms. nice amps. out of curosity i opened up the amp and was quite dismayed to see unshielded toroid transformer (not in a shielded separate cabin to protect switching noise) no input big chokes on 12 Volts supplies and NO regulating chokes after step up voltage section..... i am making a comparison with old school amp like pioneer GM-4200.
At the moment i am just thinking to upgrade the stepped up voltage regulator capacitors.... it just have a bank of 2200uFx3 rated 35V on each side of the rail i.e. 6600uF whereas the old school amps have upto 3 times the regulator capacitor , a regulating choke and a greater operting voltage tolerance i.e 50V , my plan is to increase the capacitor bank by at least 3300uFx4 on each side of supply rail with a connecting cable .
Now ,y question is the high input rush current at startup, can i damage the diode rectifier bridge or the switching supply mosfets....or do i need to add an inductance coil in between. and btw would it make difference at loud passages and imrpove SQ.
regards
Good upgrade from FOcal Utopia tn52 tweeters silver00spike Car Audio 10 3rd November 2009 10:04 PM
X-Over capacitor upgrade UV101 Multi-Way 7 1st May 2009 12:43 PM
Capacitor upgrade calvinhpk Parts 6 2nd November 2005 06:57 AM
cello encore 150 capacitor spare problems mrmcmouse Solid State 3 19th February 2005 06:37 PM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 04:21 PM
Page generated in 0.07548 seconds (71.60% PHP - 28.40% MySQL) with 10 queries
