Capacitive load testing
This might be an extremely stupid question, but when testing amplifier stability with capacitive loads, you should look at the signal BEFORE the output inductor? The output inductor is afterall there to shield the amp from whatever capacitive load it has to drive.
My own guess is yes, look at it before the inductor, but simulation amplifiers is a learning process and better to be safe than sorry.
As far as I have learned, the test point is before the L//R at the output.
Cherry even moves the test point down past the first R of the C+R Zobel, this is where he suggests one should tap off the NFB signal for more attenuation of interference coming in from the speaker leads.
