Shunt Current Feedback - Page 3 - diyAudio
Old 26th August 2011, 09:14 AM   #21
Stee is offline Stee  Italy
Stee's Avatar
Default Diamond input buffer
I would like to extend this inverting design
to an optimized one
because PRESENCE effect of this shunt configuration
really striking new features
http://www.diygene.com/schemas/a-700sch.pdf
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 27th August 2011, 07:31 PM   #22
Stee's Avatar
Default Diamond input buffer 2
see schematic
Old 28th August 2011, 03:23 PM   #23
Stee's Avatar
Default another common base amplifier
inverting amplifier class A
put R7 to GND
delete C1 and R3
R12 and R13 0,22 ohm
Battery PSU 12 + 12V
Old 28th August 2011, 03:42 PM   #24
Bigun is offline Bigun  Canada
Bigun's Avatar
what about simple version ?
> I like it. It has overtones of the Lazy Cat SSA in there too.
Or course you'll need to flesh out some details. The PSRR looks to be very risky with the simple version - unless you are using regulated supplies for the front end at least.
I have a pair of transformers somewhere, problem is they don't allow any real current as they're for small signals only. How can you modify your concept to keep dc out of the transformer.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 28th August 2011, 08:14 PM   #25
Stee's Avatar
Default TRY WITH SUPPLY TRANSFORMER BIGUN!
230V for primary
24+24v for secondary or more
transformer is mandatory with balanced signal
see this variation with unfloating input stage
and common base VAS
Copyright 1999-2017 diyAudio
