Hi ,
Can any of you tell me if there is a solid state amp with more than 200 kOhm input imp. or if there is a design where this parameter can easily be changed? Best Kris |
#2 |
You can always put a JFET/FET buffer in front of the amp and tune it to whatever input impedance you want. The buffer can be discrete or opamp based.
Sam |
#3 |
The easiest way to do this is to use a FET input op-amp in non-inverting mode. For a really high input resistance look at something like the ISL28110/ISL28210. The datasheet give it at about 550 giga-ohm! Slew rate is quite respectable at 23 V/us. You add an extra resistor in parallel with the input with the value you want it your input resistance to be.
| non inverting op amp input impedance help | sirus the virus | Solid State | 5 | 8th December 2010 06:11 PM |
| Input impedance of Arjen's amp? | robandjulz | Class D | 1 | 4th December 2009 01:00 PM |
| Question about Paradigm PreAmp, and DC Input toDH-200 & Hsu Sub | DrDan | Solid State | 12 | 18th May 2005 01:01 PM |
| Amp input impedance question ? | sam9 | Solid State | 9 | 21st April 2005 02:28 PM |
| Input impedance of a non-inverting op amp? | glennb | Chip Amps | 24 | 21st May 2004 03:24 AM |
| Page generated in 0.07292 seconds (63.13% PHP - 36.87% MySQL) with 10 queries |
