Hello friends!
I need a PCB for the amp with TDA7250? thanks and cheers |
#2 |
You could use the LME49811 instead. It is similar to the TDA7250. The datasheet from National Semiconductor has a PCB layout.
#3 |
Hi
I have all the components for the TDA7250 amplifier with output transistors 2SC5200/2SA1943! Otherwise, this circuit is much LME49811 expensive and difficult to be located? thanks Last edited by radio; 23rd August 2011 at 04:17 AM. |
#4 |
You can get the datasheet for the LME49811 here:
LME49811 - High Fidelity 200 Volt Power Amplifier Input Stage with Shutdown In my part of the world the LME49811 is available as a special order, for delivery within a week, for about US$10. It should work with 2SC5200/2SA1943 output transistors. Last edited by ingenieus; 23rd August 2011 at 10:24 AM. |
#5 |
ampslab sell such a pcb, in fact the schematic you posted is from the ampslab.com website
#6 |
Hi Jaycee!
Neither can we understand ... I need the TOP PCB layuout (See picture above!)! Regards! Last edited by radio; 23rd August 2011 at 01:45 PM. |
#7 | |
Here is the web page.
You will need different transisors for their board. The circuit is a little different from yours.
#8 |
Thanks Ingenieus!
I need PCB (Figure not Picture) for stereo amplifier with TDA7250 with output transistors 2SC5200/2SA1943, not Darligton transistors! ![]() (See schematic above) Regards Last edited by radio; 24th August 2011 at 05:33 AM. |
#9 |
Friends, for this picture to need PCB!
thanks |
| PCB International | PCB Promotion for DIY AUDIO Members | david1115 | Vendor's Bazaar | 0 | 5th March 2010 03:32 AM |
| 2x60W/1x120W audio amplifier PCB (LM4780/4732) | veteran | Group Buys | 238 | 20th December 2007 09:55 PM |
| Modified Audio Note M7 Tube Pre Amplifier PCB | rick57 | Tubes / Valves | 9 | 20th May 2006 08:21 AM |
| tda7250 | arasuk | Digital Source | 1 | 22nd January 2004 04:19 PM |
| About TDA7250/TDA1514A | MaXiZ | Chip Amps | 11 | 7th December 2003 05:55 AM |
| Page generated in 0.12318 seconds (80.16% PHP - 19.84% MySQL) with 11 queries |
