Old 21st August 2011, 05:25 PM   #1
Arroyo is offline Arroyo  United States
Default Problems PS Audio Delta 100
I just purchased a PS Audio Delta 100 in what appears to be great shape
however after 20 minutes of useage with my Apogee Calipers the right
channel made a noise ( as if cold solder joint) then a loud hum of which I
turned it off. Later re ran this channel into a standard speaker and works
fine. The only point I notice is a DC offset on the bad channel of say 1 to
2 volts at turn on ( first time power on from cold ). Secondary turn ons
voltage is low and normal .045 V DC. Have an idea something is opening up
but trying to avoid damage... The Apogees are working fine with original
amp as well and believe the load of current could be a cause of the problem
with the Delta 100... Any thoughts and or directions.
As a side note both channels run quite warm at idle...
Old 19th October 2011, 03:31 AM   #2
analogrules's Avatar
Default ps audi0
Hello Have u found the prob? I to have a PS Audio Delta 100 seems very nice a little light in the bottom end but good detail . Can u tell me how to adjust the dc offfset in my amp and what should it be at?
Old 20th October 2011, 12:02 AM   #3
Mine runs hot as well , but I do know it a class A/AB amp witch would make sense.
FS: PS Audio Delta 250 monoblocks cdfac Swap Meet 1 11th June 2011 11:59 AM
Advice sought on voltage change to a PS Audio Trio A-100 (Icepower 200ASC) pcavelle Class D 0 2nd November 2007 01:09 PM
Arcam Delta 290 problems MGriffiths Solid State 1 24th April 2007 12:54 PM
Arcam delta 90.2 - Problems wytco0 Solid State 8 26th November 2004 04:59 PM
Ps Audio Delta 250 diy guy Solid State 0 20th July 2004 09:29 AM
Page generated in 0.07861 seconds (66.09% PHP - 33.91% MySQL) with 10 queries
