Old 21st August 2011, 08:50 AM   #1
Arrow 20~50W amp
Hi
does anyone know a good amplifier circuit (Power around 20 to 50W)
I currently have an amplifier with TDA2030 Ic and it has a noticeable noise when music is not played (too much hiss)
I need a circuit with a very clean output ( without any hiss and very very low distortion)
I'm interested to have something like this ampbut of course in range above)
300 Watt MOSFET Real HI-FI Power Amplifier – Free Electronic Circuit Schematics
I built this 300W amp and I want something like this amp because it has no hiss or else at all
It would be great if I can find the parts of the amp easily.
Old 21st August 2011, 10:49 AM   #2
Elvee is offline Elvee  Belgium
If you want a really low noise, your best option is to go discrete: you can decide what input transistors you use, and this in the end determines the noise level.
With an IC, you're stuck to whatever is on the chip.
The Circlophone is a simple effective and trouble-free amplifier, designed for output powers ranging from ~10 to 100W, so it's perfect for your purpose.
Regarding the residual noise, here is what a builder said about it:
Originally Posted by odysseybmx414 View Post
Letting this channel run and listening to some select songs, I can say it sounds very good. I hooked up a better test speaker as well. Very musical, and the highs are crisp and liquid. Crystal clear.
Time to get the rest of my work done so I can get the other pcb done and listen in stereo.
Also, I am still using the small test supply with crappy filtering and bypassing. So, I expect another improvement in sound once I get a proper supply connected.
One more thing to add: The amp is absolutely dead as a rock silent with no signal. Ear crammed up to tweeter or woofer and I can perceive
nothing.
It is also very tolerant on parts, without compromising quality.
♫♪ My little cheap Circlophone© ♫♪
. .Circlophone your life !!!! . .
Old 21st August 2011, 02:16 PM   #3
Thank you so much "Elvee"
which schematic of your design can I use for sure?
The first post of the thread #1 ?????
Old 21st August 2011, 02:48 PM   #4
The schematic of #1 is correct, and if you need the PCB files, here is the current version:
They have been tested and validated.
If you prefer the pdf version, OdysseyB. has made the conversion:
You will also find a summary of useful informations here:
Old 21st August 2011, 03:25 PM   #5
I don't really know what to say
Thank you so much
50W amp zeus_threat Solid State 64 5th September 2007 08:27 AM
HELP-- I need a simple 50W AMP circuit --- MTO audio Solid State 5 9th August 2007 06:46 AM
50W - 100W Amp for Subwoofer Anfield Solid State 8 14th September 2006 08:18 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 07:30 PM
Battery powered portable Class-D mono amp >50W RMS tonfelix Class D 1 29th April 2006 02:08 PM
Page generated in 0.09011 seconds (75.27% PHP - 24.73% MySQL) with 10 queries
