Old 18th August 2011, 05:48 PM   #1
Default AV400
I intend to construct two channels of of the popular AV400 MOSFET amplifier. I have redesigned the PCB which was previously posted by some viewer of DIY audio site. This PCB accommodates large reservoir capacitors. The original design is not mine. Can some one debug the PCB from the schematic.
Old 19th August 2011, 03:41 AM   #2
Sorry the PCB image file was left inadvertantly.
Old 3rd September 2011, 07:02 PM   #3
Has anyone assembled AV400 Amplifier. If yes, what is the performance, distortion level etc.
Old 3rd September 2011, 07:06 PM   #4
NMOS is offline NMOS  Germany
NMOS's Avatar
I prefer to use QUASI NMOS300/500
its proved Design hundreds pcs. are build
you can find ..... power amp under development
Old 3rd September 2011, 07:13 PM   #5
Thanks for advise.
Old 3rd September 2011, 10:10 PM   #6
That's why I use net lists. If the schematic is correct, the PCB connections will be too. BTW, where is the schematic to compare to?
Old 6th September 2011, 02:20 AM   #7
Revised PCB layout with Carbon ! watt power resistors and Zobel network.
Old 1st October 2011, 05:25 PM   #8
Default Mistakes corrected
Mistakes were found in previous layout which have been corrected. Interested readers may check the layout with AV400 Schematic.
Old 16th October 2011, 07:43 AM   #9
Default AV400 PCB ETCHED
I have just now etched pcb for AV400. More pictures later
Old 16th October 2011, 01:12 PM   #10
PCB is very good. But it should be better if made with fiberglass board instead of phenolite.
The AV400...... aleopeldd Solid State 11 16th September 2008 11:18 PM
Av400 fjromero Solid State 0 28th April 2007 12:32 PM
PCB for AV400 bigpanda Swap Meet 12 9th July 2005 05:27 AM
my AV400 is back bigpanda Solid State 20 25th May 2005 11:23 AM
need help with AV400 pcb jZZ Solid State 5 31st March 2004 11:06 PM
Page generated in 0.09343 seconds (73.70% PHP - 26.30% MySQL) with 11 queries
