#11 |
Hello
excuse me if it was asked before . I have some problem with my newly built av400 amp.i don't know how to set to multiturn potentiometer to access the best sound quality and avoid produce excessive heat on IRFPs. I wonder if it's possible for you to help me how can i set it practically . I was reading the instruction written by Mr holton but i didn't get the point. |
#12 |
measure the voltage across your 1ohm source resistors, adjust pot for your required current.
i would suggest 10mV as a starting point, check all devices at this level, they should be 9-11mV if matched sufficiently. When you have finished build, then try adjusting to suit your taste, heatsink etc. many threads already on this topic. |
#13 |
if you mention the 5-watt resistor of source pin of each MOSFET, it should be noticed that they're 0.22 ohm not 1 ohm. now do i make a mistake or you mention something else?
#14 |
fortunately I got the point .
but my resistor voltages are varied. i set the highest voltage on 18mv but the others are 9mv and 10 mv and even 3 mv . how can i match the MOSFETs together. and what happend if they still unmatched? thank you for helping me. |
#15 |
i've read the instruction for matching the MOSFETs but do i need more than 4pair of IRFPS to have the closest match or not?
could anyone explain how to match them? |
#16 |
PCB AV400 R1 ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
| The AV400...... | aleopeldd | Solid State | 11 | 16th September 2008 11:18 PM |
| Av400 | fjromero | Solid State | 0 | 28th April 2007 12:32 PM |
| PCB for AV400 | bigpanda | Swap Meet | 12 | 9th July 2005 05:27 AM |
| my AV400 is back | bigpanda | Solid State | 20 | 25th May 2005 11:23 AM |
| need help with AV400 pcb | jZZ | Solid State | 5 | 31st March 2004 11:06 PM |
