#181 | |
But the more important question should be, what is the intention behind the switching ? Ok, to avoid the obvious- if you want to compare to power amplifiers, you have to exchange the loads (aka loudspeakers) and inputs. But, is rapid switching needed or could you just stop (or fade out) the music and do the switch after that? Is a switch box a must have or would manual switching already be sufficient? These questions are connected to the question of practical relevance of any test results and to questions of test strategies and efficiency as well. |
#182 | |
Yes, rapid switching is a requirement, so switching cables will not do. Fading in and out the source signal could be envisaged but it would be an additional complexity. |
#183 | |
The first relay should have wolfram based contact material; the other should have some nice high quality contacts. Switching off would be done in reverse order. I guess that youŽll use the box for listening tests, right? Then you should better use relays for the input signal as well. This way you will cancel the possibilities for any current loops within the two DUTs. Even when driven by a low impedance preamplifier stage this will most probably happen within the ground wires. (Symmetrical drives might be different if realized in a proper way) If listening test results should have practical relevance iŽd question the need for rapid switching; if a difference is only detectable with rapid switching (because listeners aural memory is weak) why should it be of relevance for normal listening? You would simply not notice any improvement the next day. ![]() Otoh rapid switching might lead to a different "awareness" which could prevent participants from "holistic" listening. |
#184 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
1) Funk the EU ROHS regulations and get surplus mercury relays while you can (I am just contemplating to buy a job lot of 1k 4-Way mercury wetted reed relays). 2) Do switch the unused amplifier to a dummy load. 3) Mute during switching, making sure not to un-mute until the relay is reliably closed. The above makes sure that amplifiers that can take damage without load but with signal (e.g. Vintage Tube Amp's) are protected. Ciao T |
#185 | |||
I'm afraid it will be very difficult to detect any difference between two good amps, even when using fast switching ! I'd rather do an easier test first (try to find differences with fast switching) and if that goes well maybe take on a more difficult one. In the realm of statistically significant differences when listening it seems that the norm is negative results, at least with modern amps. |
| Double blind test of cheap/fake phono connectors anyone? | cr0wl3y | Everything Else | 3 | 26th February 2011 02:41 PM |
| ABX double blind comparator - original | Speaker Dude | Swap Meet | 4 | 18th March 2008 07:40 PM |
| Double Blind Testing | pjpoes | Everything Else | 75 | 25th September 2005 01:31 PM |
| GainClone PS auditions | analog_sa | Chip Amps | 27 | 28th October 2003 11:14 PM |
| Capacitors and double-blind listening tests | MarcelvdG | Parts | 9 | 24th May 2003 02:39 PM |
