Old 27th August 2003, 04:52 PM   #1
Default how do you design a class d feedback network?
I'm also building my first class D audio amplifier but before I begin I was wondering if anyone could provide some advice or foresight to this project.
Here it goes:
I'm looking for a bandwidth of approximately 20khz and an output of around 500W RMS into an 8 ohm load.
I'm considering using the HIP4080 as my low and high side mosfet drivers. It has an onboard comparator and dead-time so I'm thinking all I need to do is put a 200khz triangle wave on the non-inverting side of the comparator and my level shifted audio on the inverting side. The HIP4080 will drive an h-bridge output with 3 mosfets in parallel on all 4 "corners" of the h-bridge. This bridge will feed a lowpass filter with an Fc of around 30khz.
As of now I'm a little confused with the design of the feedback network. From what i've seen i should use an opamp on the output (after the filter) to subtract the (+) and (-) of the signal out and feed this back to the comparator input??? I'm a little confused about this....
Thanks in advance!
Randy Knutson
Old 27th August 2003, 07:32 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
In my SONY TA-N88 the PWM signal itself is fed back to the right hand gate of the input differential fet amp stage.
BUT, there is a cap between this point and the collector of the PNP driven from the load resistor of the left hand input fet, that makes it an integrator.
So, it looks what you need to do is to integrate the PWM signal (for switching freqs at least) and use that signal as a conventional feedback signal to the analog input circuitry.
Jan Didden
Old 27th August 2003, 08:24 PM   #3
There are two places to look at:
1.) The respective HIP4080 application note.
2.) This tread: My very first Class D pwm (switching) amplifier.
Charles
P.S.: Take care about the IC's output-current capabilities when driving so many FETs in parallel !
Old 30th August 2003, 07:00 AM   #4
DUG is offline DUG  Canada
Read the pdf ap-notes for the 4080 and its' evaluation kit ... there are at least 3
Calculate the combined gate charge required for your 3 FETs, the gate drive current output of the 4080, and the resultant turn-on time. You may find that 200kHz is too high.
I have a 2 layer board designed but have not moved this project up my list very far.
(opinion)
The feedback network is not the greatest hurdle, the output filter is!!
Doug We are all learning...we can all help
Oscillation due to (probably) feedback network Mambo Solid State 21 6th November 2007 03:49 PM
Help with Class D Amplfier Design (feedback) hypnopete Class D 251 12th July 2007 01:47 AM
Purpose for RC network on Feedback corrieb Solid State 8 10th January 2007 08:23 AM
Page generated in 0.09522 seconds (74.87% PHP - 25.13% MySQL) with 10 queries
