My son's little 2x40W Onkyo DR-645 stereo has a subwoofer output (full range, mono, post vol control), and he has expressed an interest in building a little amplifier and sub.
I've built a couple of gainclones, but power opamps hide the details.
Can anyone suggest a simple, discrete circuit we could build together?
Something simple enough to wire point to point would be great.
Any suggestions appreciated,
S
S
How much power do you want that sub amp to put out? My guess would be 80W, and such things are not so easy to do simple.
One way to keep a power amp simple is to use the LME49830. It does hide some of the functionality, but the circuit is simple enough to wire point to point. Not sure if this method of construction is a good idea, haven't tried it myself. The datasheet for the LME49830 has a PCB layout.
Even simpler is to use the LME49810/LME49811 with Thermaltrak transistors - therefore no Vbe multiplier needed. The easiest way to do that is to get one of these kits. Very serendipitously, it puts out 80W.
http://www.pansonaudio.com/Compact_Series.htm
Disclaimer: I am not affiliated with these guys, but I like what they do. And they hang out on this forum AFAIK.
Something of this kind:I've built a couple of gainclones, but power opamps hide the details.
2N3055 Power Amplifier
It's safe, proven and works well enough.
For a sub, increase the 1500µ output cap to 4700µ.
To simplify it further, you can replace the OP transistors+drivers by monolithic power darlingtons.
Or go for something really crude and nasty, like this one:
Cheap 100 to 150 Watt Amp
And finally, the darlington version: linearity is even better.
Q1/Q2 can be a single monolithic low power darlington like the BC517
I like this one - simple, cheap and easy to build with no bias to adjust.
If one is willing to make adjustments, a Vbe multiplier in place of the diode string would improve the THD a little.
Yes, and in practice, R6 should be made adjustable too, to set the output at mid-supply.I like this one - simple, cheap and easy to build with no bias to adjust.
But it will work as it is, with a slightly reduced output dynamic.
- Simple sub amp a 10-year old could build?
