searching for an power amp design
Old 12th October 2003, 08:53 PM   #21
darkm4n is offline darkm4n  Romania
darkm4n's Avatar
Send a message via ICQ to darkm4n Send a message via MSN to darkm4n Send a message via Yahoo to darkm4n
Default Ok ...
For the PCB : http://www.astro.uu.se/~marcus/private/m250.html
You will find them at the end of the page .
Ok .. there is a diference .. for shure i overheat some traces , but there is nothing un normaly on the B E C of the output stage .
I think the only thing left is the stupid bias pot that i will change tomorow ...
I don't have any other idee from where that distorsion comes .. and the heat ...
If the BIAS is not the problem the only thing i can do is to switch the output stage from the good channel to the bad channel .. to see if the output stage is the bug or something on the board ...
Who know .. maybe the distorsion is not from the board ... maybe PSU , wireing ... etc ...
Bye , Mihai .
Old 14th October 2003, 11:47 PM   #22
Diode is offline Diode  United States
God, I hope we don't have another DJBASSAMP on our hands!
You must have deep pockets if you are just guessing what parts to change. Yes, check that the power supply is wired to the board correctly and also make sure the polarity of your parts is right. Make sure that you didn't put the PNP parts where the NPN parts go. That is a fairly common mistake you know......
Chris
The best audio is clean audio!
searching for an power amp designHide this!Advertise here!
Searching for switching power supply schematics sekanix Power Supplies 5 12th June 2008 11:30 PM
Searching for FE167 Karlson Design bluegti Full Range 14 11th March 2007 07:42 AM
trying to design a power amp rx7speed Instruments and Amps 4 27th November 2004 11:41 PM
My X-Power amp design blu_line Solid State 3 1st February 2004 12:58 PM
