Old 15th August 2011, 01:02 PM   #1
Happy Chappy
Fivetide's Avatar
Question Amp is not bi-wired Speakers are :(
Hi, I bought a CA Azur 650 A + CA DacMagic at the weekend, it sounds fantastic out of the box .. but there’s a down side L its not a bi-wired amp, and I my speakers are. Could I modify the amp to become bi-wired, it already has 2 sets of post for a second room setup,, ( reason I thought it was bi-wired ..doh !) or should i build an external cross over.. or just leave the post connected and single mode. Which do recommend ?
Old 15th August 2011, 01:23 PM   #2
picowallspeaker's Avatar
I don't think that a 'bi-amp ready' amps exists ,maybe a few ,and only DIY !!
So you just need to attach two wires on the same plug .
And use the 'search' feature ,because the argument has been talked over and over ...
Old 15th August 2011, 03:49 PM   #3
Just get banana plugs that can be stacked and plug them into your amp.
Old 15th August 2011, 03:53 PM   #4
Speakerholic
Cal Weldon's Avatar
Do the dual terminals have jumpers? Show us a pic if you can.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th August 2011, 04:10 PM   #5
Happy Chappy
Fivetide's Avatar
My Bad .. I've misunderstood how the bi-wired speakers are actually wired..
Old 15th August 2011, 04:15 PM   #6
Speakerholic
Cal Weldon's Avatar
It's easy to mix up bi-wired and bi-amped.
Old 15th August 2011, 04:24 PM   #7
Happy Chappy
Fivetide's Avatar
I was confused becasue my first bi wired amp was my sony and the wireing is setup as in the pic
Now I realise thats not a typical setup from an amp.. sorry for the mistake
Old 15th August 2011, 05:38 PM   #8
benb is offline benb  United States
If you connect one set of cables to the receiver's "Speaker A" output and the other to the "Speaker B" output, be aware than many receivers when put in the A+B mode put the A and B speakers in SERIES, which will not work correctly (though it will make sound and won't hurt anything). If your Sony was like this, the "correct" bi-wiring to your new amp will make these speakers sound quite different!
Old 15th August 2011, 07:51 PM   #9
This is what I meant.
bi-wired speakers terteliu Multi-Way 14 19th June 2011 02:58 PM
Speakers for Bi-Amp Set-up MVZIK Multi-Way 3 8th November 2009 11:10 AM
Bi-Amp 3.5 Way Speakers slhijb Multi-Way 18 18th September 2008 11:23 AM
Bi-amp Existing Speakers??? LLDeese Multi-Way 11 20th March 2007 04:05 AM
bi-amp for diy speakers biff584 Multi-Way 7 15th November 2002 08:23 AM
Page generated in 0.10399 seconds (74.58% PHP - 25.42% MySQL) with 10 queries
