ground loop breaker
ground loop breaker
Old 27th August 2003, 02:07 AM   #1
biff584 is offline biff584  United States
Send a message via AIM to biff584
Default ground loop breaker
I built a P3A amp and was having problems with ground loops, so between the amp's signal and power grounds and the earth ground I place a loop breaker consisting of two diodes in parallel in opposite directions and a 10 ohm resistor. This greatly reduced the ground loop, but I can still hear it- are there any other adaptions I can make to further reduce the effects? I was thinking about upping the size of the resistor, removing the resistor, or maybe even trying to add a simple RC low-pass filter designed to reject frequencies at and above 60Hz between the signal and earth grounds.
Thanks alot.
Brian.
Old 27th August 2003, 11:15 AM   #2
trwh is offline trwh  United Kingdom
trwh's Avatar
Hi
You could try increasing the value of the resistor - although I wouldn't leave it out altogether. In one design I saw a 100 ohm part used; as long as you keep the diodes any value is safe to try. Many designs also use a 100nF mains rated capacitor in parallel with the other components to bypass the resistor at high frequencies.
Hope this helps,
Tim.
Old 27th August 2003, 12:03 PM   #3
Thanks, I'll give that a shot and try a 100 ohm resistor instead and see if it help much.
Brian.
Old 27th August 2003, 12:20 PM   #4
ukram is offline ukram  Finland
Try reading Jensen application notes.
http://www.jensen-transformers.com/apps_wp.html
You should show us a picture with the ground connections of your whole system...
ground loop breakerHide this!Advertise here!
Diode bridge as loop breaker question Tyimo Pass Labs 48 13th December 2016 04:28 PM
How save is a ground loop breaker? k.junold Solid State 0 14th October 2004 07:47 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
