#51 |
Hi ben goh,
Many thanks for your answer. Is the mosfet IRF 610 and 9610 better as the old mosfet typ. Must I machting the new mosfet IRF 610 and 9610 Best regards Alex |
#52 |
Actually the direct replacements according to the book
are irf9612 and irf612. Enhancement mode fets used as current sources. In this case the Rds is important. These are not so easy to get either. |
#53 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#54 |
Must matching the fet´s IRF 9612 and 612 for KSA 100 ? Alex |
#55 |
Alex,
Why do you bother about fets ?. Typically you will find that the output transistors, maybe driver transistors and maybe emitter resistors only are blown - it is rare for damage to go further back. Your friend should know what a variac is - use one to run up the amp whilst monitoring bias current one channel powered at a time. If you need more info just ask. Eric.
I believe not to believe in any fixed belief system. |
#56 |
Eric is correct,
The parts that get damaged or the or the NPN and PNP outputs emmiter reisstors and maybe the bias transistor. Do not get concerned about the front end of the amp. In addition, many companies still sale these components. You just need to search the Internet for the companies. These are still a market for discontinued transistors.
Jim W. |
#57 |
Where can I buy the dale resistors and the Panasonic FC Serie at Germany? Dale CMF 60 75R0F Panasonic FC 105C 1000uf/16 Volt I have by ten dealers to ask. No Dale resistors and Panasonic capacitors Best regards Alex |
#58 |
For panasonic check http://www.schuro.de/preisl-pana-fc.htm
#59 |
Hi
NO! undeliverable by Schuro.de By by Alex |
#60 |
Hi
Can me to sell anyone the Dahl resistor RN60D 75R0F or CMF 60 75R0F ? Alex |
| DIY Car Repair | avatar307 | The Lounge | 6 | 22nd May 2011 10:19 PM |
| DHD should repair? | Solosound | Car Audio | 5 | 9th November 2008 07:39 PM |
| my amp repair | benlebow | Car Audio | 3 | 10th February 2008 12:30 AM |
| Nad 304 repair | big jim | Solid State | 0 | 30th December 2006 11:19 AM |
| CDM 9/44 to repair CDM 9 Pro | Duson | Digital Source | 1 | 12th October 2005 04:41 PM |
| Page generated in 0.11802 seconds (71.92% PHP - 28.08% MySQL) with 11 queries |
