Old 11th August 2011, 01:13 PM   #1
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Default Blameless-like amp burnt channel need help to prevent that happening again!
I need some help to prevent my Blame ST from being injured once again since one channel has been burnt after an accidentally TV turn off and on.
Both rail fuses (2.5A), and two transistors (Q9 driver and Q12 output) have died.
Q9 is a BD139-16, and Q12 is a MJ4502 (Q11 is a MJ802). Both transistors lost the B-E junction, due to some overcurrent caused by the "thump". I haven't checked speakers yet.
Since a I am not a designer, could anyone help me adding some devices in order to prevent this happening again?
Thank you very much!
Max.
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 11th August 2011, 03:40 PM   #2
farjon is offline farjon  Brazil
farjon's Avatar
Hi, Max.
I didn`t have this problem in my Blame ST yet. So, I can give only general suggestions.
1- As a VAS protection, I would use (not tested) the D12 diode mentioned here:
Dx Blame ES .... based into the Blameless, i am trying a new amplifier
2- Install catch diodes on Q11 and Q12.
3- Check that the 2K2/2W resistors are installed on power supply outputs. Some people also recomend a kind of catch diodes here.
4- Are you using the DC protection board?
If both rail fuses has died, I think some kind of cross-conduction, when both output transistors conducted simultaneously... what a kind of transient at this TV turn off and on! Can't say who died first and drag the other.
Well, at least avoid turn on-offs with high volume levels sets.
Old 11th August 2011, 04:26 PM   #3
The design lacks a VI limiter, but it's an open question whether that would have helped.
Old 11th August 2011, 04:50 PM   #4
smartx21's Avatar
Originally Posted by Sound_Buster View Post
Hi, Max.
Thank you for your kind support, my friend.
I had been careful most of the time with both amp and TV set volume controls. But that night I was kinda asleep when my 10-year-young son did that deadly operation! I only noticed in the morning what had really happened!
The answer for questions 3 and 4 is YES.
Old 11th August 2011, 05:10 PM   #5
dadod is offline dadod  Croatia
dadod's Avatar
Insert protection resistor of 1k between Q6 collector and the ground.
Old 11th August 2011, 05:56 PM   #6
farjon's Avatar
More on these diodes here:
Power amp under development
Old 14th August 2011, 03:36 AM   #7
thaumaturge's Avatar
If Q8 opens the outputs will slam to the rails. A stack of two diodes paralelling it shouldn't affect normal operation but might be enough clamp to save some output devices.
Doc
Ne timeas a facie mulierum ea ignorare
Blameless Amp layout Ipanema Solid State 83 11th March 2010 08:13 PM
blameless amp and doug self streetera Solid State 17 16th July 2007 10:06 PM
very odd thing happening in my amp... help AudioGeek Tubes / Valves 15 25th September 2005 02:34 AM
Page generated in 0.11731 seconds (71.39% PHP - 28.61% MySQL) with 11 queries
