simple PSU Question.. - diyAudio
Old 26th August 2003, 10:49 PM   #1
deepanger's Avatar
Send a message via ICQ to deepanger
Question simple PSU Question..
wanna build a PS. for a small amp. which runs at about 12v.
(11-14v. range), with a max. current consumption of 5A
ive one trans. 12v. rated at 10A, a 6A bridge and as much
capacitance as needed..
how to achieve agood regulation? ,volt. regulators above 1.5A
arent available in here, so can i just use a 12v. zener diode??!
or maybe theres better solutions?
thanks all..
((DeepBass = DeepAnger))
Old 27th August 2003, 11:14 AM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
well thats a simple voltage regulator that u can make for your needs
Old 27th August 2003, 12:08 PM   #3
no picture appeared
Old 27th August 2003, 12:41 PM   #4
JOE DIRT®'s Avatar
I`ll take it is an automotive amp....for one thing they do not need a regulated supply there is one built in.
all this amp wants to see is a voltage source between 11-17 vdc and enough amperage available from the source
I would rectify and filter your power supply and thats all that is needed
DIRT®
Old 27th August 2003, 12:41 PM   #5
sss's Avatar
stupid geocities server
Old 27th August 2003, 12:46 PM   #6
Marvellous's Avatar
This circuit should Work for you!
The value of C2 is dependent on your input voltage
and should be preferebly more than your input Voltage
"When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute—and it’s longer than any hour. That’s relativity." - Albert E
Old 27th August 2003, 01:02 PM   #7
sss's Avatar
hi Marvellous
your circuit is transistors Vbe depanded ,Vout will be lower at higher currents , but its better them my circuit for deepangers application
Old 27th August 2003, 07:43 PM   #8
deepanger's Avatar
aah, u mean to use one of those lm7812 volt. regulators for ex.
combined with a 12v. 10A passing transistor..
so any recommendations about the transistor??
and what about the filtering capacitance?
Old 28th August 2003, 08:16 AM   #9
Marvellous's Avatar
The transistor Vce should be 12V or more
Ic should be 5A or more
Capacitance can be Higher than 2200uf if you wish!
but the input capacitor should have a higher voltage rating than your input voltage! just to be safe!
Old 28th August 2003, 08:48 AM   #10
sajti is offline sajti  Hungary
I recommend to connect one diode in series with pin #2 of the 7812. With this modification You can get 12V output egzactly. The series pass device can be any high power NPN device, such as TIP35/BD249/MJ15024 etc.
Sajti
A simple question from a simple man. inteificio Solid State 5 17th October 2005 04:00 PM
Simple Question stoN_Cold Solid State 2 3rd October 2005 11:56 PM
Simple question... Quattor Solid State 7 23rd June 2004 06:41 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 11:05 AM
A Simple Question OMNIFEX Multi-Way 3 19th July 2003 09:11 PM
Copyright ©1999-2017 diyAudio
