The most common cause of speaker buzz from an amp?
Old 10th August 2011, 10:56 AM   #1
Fivetide is offline Fivetide  United Kingdom
Question The most common cause of speaker buzz from an amp?
What would be the most common cause of buzzing through your speakers when attached to the amp? This is my QED P300 project and I would first like to find the fault that is causing the amp to create buzzing in the speakers. The speaker are TDL RTL2ís mark 1ís they have 8 ohms independence and I have them hooked up to a Sony AVI system thatís bi-wired and 8 ohms and they make no noise at all when not being fed. One thing I have noticed is that when I power on the amp via the front switch it makes a sort of popping sound, an audible click through the speakers. The buzzing also increases as I increase the volume via my pre amp. Iíve tested the pre am on my friend arcam and it makes no noise at all when not being loaded.
So the question is , if this was a problem with your amplifier what would you suspect is the main reason for buzzing? I need to start somewhere so eradicating the reason itís been stuck in the loft for the last 8 years may a good point to start.
I've put a picture of the naked amp below :
Old 10th August 2011, 11:04 AM   #2
Confirm again:
Does the Volume Control turn the Hum Buzz off completely?
Either use a 200mVac scaled voltmeter, or listen carefully, with the house silent, and your ear 20mm from the driver centres.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th August 2011, 11:17 AM   #3
Hi Andy, no the buzzing does not go away even if the pre amp is not attached. The QED has no volume control on it just the Rotel Pre amp.
Old 10th August 2011, 11:19 AM   #4
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
you have hum in the preamp stage, or a bad ground on one of the inputs. the amp itself is probably ok.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 10th August 2011, 11:27 AM   #5
Originally Posted by Fivetide View Post
...............I have them hooked up to a Sony AVI system that’s bi-wired and 8 ohms and they make no noise at all when not being fed..................The buzzing also increases as I increase the volume via my pre amp. I’ve tested the pre am on my friend arcam and it makes no noise at all when not being loaded.
Originally Posted by AndrewT View Post
Confirm again:
I did not ask what happens when you disconnect the Power amp from it's sources.
regards Andrew T.
Old 10th August 2011, 11:45 AM   #6
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I'm a bit unclear about this also. I understand the buzzing is present from the idling amp. Is the buzzing present with the preamp volume all the way down, and gets louder as the volume is turned up? Or is the buzzing absent when the preamp volume is turned all the way down?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th August 2011, 12:00 PM   #7
Sorry for the confusion Andy
Hi, when amp alone is attached to the speakers it buzzes, when I add the pre amp and turn the volume up the buzzing increases. But I would say the buzzing does not increase in proportion to say a CD playing. The sound from the source will drown out the buzzing very quickly when I increase the volume.
I need to test if the buzzing goes when the pre amp volume is turned to lowest , I will post tonight.
Old 10th August 2011, 12:11 PM   #8
mymindinside is offline mymindinside  India
What happens if only one channel is connected at the source, but both speakers are connected to the power amp.
cheers,
mymindinside
Old 10th August 2011, 12:22 PM   #9
cheers,
mymindinside
Good idea I will test this and post later , thanks.
Old 10th August 2011, 05:01 PM   #10
I have now tried the amp with nothing connected except one speaker, and it buzzes , i swapped the speaker to the other channel and the same thing.
The most common cause of speaker buzz from an amp?Hide this!Advertise here!
Need speaker A/B switch without common (-) connection sprinter Multi-Way 3 20th April 2011 07:27 AM
Speaker protection and common ground ads2 Chip Amps 7 1st January 2011 11:42 PM
Got the speaker buzz genmin Everything Else 5 13th December 2009 10:19 AM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
How to model speaker interaction in common chamber dih1118 Multi-Way 0 22nd September 2003 02:25 AM
Copyright ©1999-2017 diyAudio
