Old 9th August 2011, 11:22 PM   #1
Default Upgrade for TIP35/36 outputs
I have an amp that uses 125w Tip35/36 outputs and it gets quite warm.
What could I replace them with that handle more power?
What about Mjw21195/96 200w?
Reason I ask is because Tip is 25A part.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 10th August 2011, 12:00 AM   #2
nigelwright7557's Avatar
What ever you replace them with will get just as warm with the same heatsink.
I would go for a bigger heatsink and/or a fan.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th August 2011, 12:44 AM   #3
I can't change the layout, I want better transistors so it will have better SOA when hot.
Old 10th August 2011, 12:48 AM   #4
Most silicon works up to 150 degrees C with some exceptions.
Can you not fit a small DC fan ?
Old 10th August 2011, 01:02 AM   #5
The amp has 3 pairs of outputs for each "channel" 6 pairs total.
It has a fan already. It's a 400w/800w @ 4/2 ohm btl mono amp.
It got warm with only 4 ohm, didn't try 2 yet.
I think its a lot of power to ask from those outputs, so I'm wondering what's better.
Old 10th August 2011, 01:31 AM   #6
jaycee is offline jaycee  United Kingdom
If you're really set on changing transistors then yes MJW21193/4 would be a good choice. However getting rid of the heat is the problem..
swapped TIP35/36C overheating/blowing fuse immediately runnamukk Solid State 9 14th March 2011 07:05 PM
Longer lead TIP35 and 36 spiette Parts 7 2nd December 2009 10:15 AM
Smps 36-0-36 500w microp Car Audio 19 12th July 2007 12:33 PM
Please help / sub amp TIP35/35C Risto80 Car Audio 7 21st May 2007 09:52 AM
Page generated in 0.08501 seconds (71.38% PHP - 28.62% MySQL) with 10 queries
