THD calculations
THD calculations
Old 23rd January 2002, 02:19 PM   #11
tiroth is offline tiroth  United States
Hmm, no more editing after 10 minutes, eh? I should have said the phase response was "closer" to linear. I'm looking at bounds of 18 degrees, with the average phase shift being much less.
Old 24th January 2002, 11:05 AM   #12
djk is offline djk
djk's Avatar
"1/3 oct EQ with only one opamp? That sounds interesting, have a page on it?" I have a couple of pro-sound eq made by DuKane that have only one op-amp per channel.They have a single ended class A single transistor input buffer and a single differential gain stage for the filters.The filters are all passive LCR.But a hybrid is also possible.Dynaco used LCR filters for the upper bands and gyrators for the larger low freqency inductors. If you look at the schematic for the McIntosh MQ104 parameric eq it is the same, earlier versions used a single transistor for the gyrator.If you use pots with a center tap and ground the tap the eq is effectively out of circuit with the pot near the center position.My DuKane actually have a switch on each band! These old dinosaurs make the new 60 op-amp stereo models sound really bad.
THD calculationsHide this!Advertise here!
BIB Calculations davidallancole Full Range 44 11th March 2007 03:04 PM
Need help with calculations please. Wynand Solid State 6 27th June 2006 01:00 PM
x over calculations bcycle Subwoofers 10 8th February 2006 06:58 AM
calculations lXxAndyxXl Multi-Way 8 19th October 2004 04:53 PM
