A different input stage - diyAudio
Old 26th August 2003, 11:52 AM   #1
kyrgeo is offline kyrgeo  Greece
Default A different input stage
Virtually all differential input stages have a common emitter differential pair. This configuration suffers from the Miller capacitance multiplication effect, and has therefore low bandwidth.
Cascoding with a common base stage reduces the Miller effect, and increases bandwidth. This is straightforward and has been done often.
I was wondering why the common collector (emitter follower) "cascoded" by a common base stage is not used. The emitter follower inherently does not suffer from the Miller effect, but does not provide voltage gain. Therefore we use a common base stage, where the Miller effect is also absent, to provide the voltage gain. The emitter follower should be more linear than the common emitter stage...
Why has the CC-CB configuration not caught on, like the CE-CB cascode?
Has anybody any experience with it?
Pan metron ariston
Old 27th August 2003, 02:53 AM   #2
john curl's Avatar
This type of input stage was first used in the LM101 in 1966 or so.
Old 27th August 2003, 03:49 AM   #3
Hello -
I don't really see how one could make a differential amplifier with your proposed input stage.
Charles Hansen
Old 27th August 2003, 03:57 AM   #4
Hello John,
I found the schematic for the LM101 on National's web site at:
http://cache.national.com/ds/LM/LM101A.pdf
I looked at it for around 3 minutes, but my head exploded before I could understand how it could possibly work. Any insights would be appreciated!
Thanks,
Charles Hansen
Old 27th August 2003, 04:22 AM   #5
Steve Eddy's Avatar
Default Re: A different input stage
Dunno. Been wondering the same about the Xfrmr/CC configuration.
se
Old 27th August 2003, 04:39 AM   #6
andy_c is offline andy_c  United States
Banned
Hi Charles,
There's a PDF file at this site:
http://www.stanford.edu/class/ee214/.../ho18opamp.pdf
which discusses detailed design information of the 101 among others. It's a good read.
Andy C
Old 27th August 2003, 04:40 AM   #7
jam is offline jam  United States
jam's Avatar
Default Warning! Off Topic Post.
Charles,
I thought you might find this a source of amusement.............
http://www.lunaticlounge.com/fringefiles/explode.html
Jam
Old 27th August 2003, 05:41 AM   #8
Hello Andy,
Wow! Thanks for the great link. I haven't had time to fully digest it (my head hasn't fully re-integrated after the recent explosion), but it's really, really good! Did you take this class, or did you just stumble across the file?
I still have a question. In the file you referenced, the author states, "connect the PNPs (Q3/Q4) in a differential common-base configuration".
I didn't know you could do that! Does anyone have any references for that circuit? It seems like the beta for the two transistors would have to match *exactly* for this to work. Even then, it seems a bit sketchy to me.
Thanks,
Charles Hansen
Old 27th August 2003, 05:58 AM   #9
Steve Eddy's Avatar
How 'bout if you look at the transistors as transconductance devices rather than current amplifiers as John once advised?
se
Old 27th August 2003, 08:04 AM   #10
bocka is offline bocka  Germany
With discretes it's very difficult to get a well balanced differential stage. transistors must have the same . So you have to use duals for NPN and PNP and control the Ibias for the differential pair. It's only good/simple solution for chips
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
input cap at D1 I/U stage Klaus Pass Labs 3 30th December 2003 11:00 AM
Input stage Andrey Solid State 5 21st June 2002 01:32 PM
Copyright 1999-2017 diyAudio
