spice model for 2SK711
Put the Id vs Vds chart from the datasheet on your lap, plug in a JFET of known parameters into the simulator and perform DC sweep. Change the parameters until you've got a set which resemble those in the datasheet. It only takes a couple minutes.
The standard SPICE model of the 2SK170 in my simulator (Multisim) seems to be for a "V-Grade" device so I adjusted the parameters until I get the Idss for the BL and GR varieties -- copy these down and use for your own device library. It's nice if you have a curve-tracer to check your work, but you can do the same analysis with a pair of power supplies and a DVM and graph in Excel.
