Old 4th August 2011, 02:06 PM   #1
Default Which AMP should I use?
I am building a portable boombox running on a 12V 7Ah battery. I am powering two 5.25" Coaxial drivers. (93 db sensitivity).
Which amp should I use:
The Dayton DTA-2
The Lepai TA2020
or
The SURE TA2024
I am worried about the voltage requirements for the SURE TA2024. I heard it will perform better at 24V. I a using a 12V power source.
Thanks,
JV
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Page generated in 0.04823 seconds (75.10% PHP - 24.90% MySQL) with 10 queries
