I am building a DX Blame MKII Supercharged and I was wondering If it was a big deal to replace some of the transistors with the types I have on hand.
With these: Small Signal: 2N5551 = KSC1845FTA 2N5401 = KSA992FTA VAS Transistor: MJ15032 = KSC3503 Driver Transistors: MJ15032 = KSC2690A MJ15033 = KSC1220A Output Transistors: MJL4281A = 2SC5200 MJL4302A = 2SA1943 VBE Multiplier: BD139 = KSC2690A |
#2 |
The 992/1845 has higher voltage and higher hFE and lower current ratings.
I don't have 3503 data. The 1220/2690 have lower current and lower SOA ratings. Don't use them with 4ohm speakers unless your reduce the Rail voltage significantly. The 1943/5200 have the same problems as the 1220/2690. Don't use them for 4ohm speakers. 6ohms speaker might be gentle enough, but I'd recommend usage only with 8ohm or higher impedance speakers.
regards Andrew T. |
#3 |
As Carlos would say: do NOT change anything!!! Use what is stated in the schematic or come up with a design of your own, using the transistors you have.
The point of life is to build atleast one audio amplifier before you die. |
#4 |
It should work well. You may have to adjust the compensation but I don't think so.
#5 |
IMO a good design should be able to work with similar transistors or rather ones with the similar characteristics in play. I see no reason why one couldn't use this circuit with the transistors they already have lying around. The IPS diff bias is about 2.3mA per leg so KSC1845/KSA992 would suffice here. Perhaps adjusting R5/R6 & R8/R9 to reflect the change in beta and %difference of re'. It may be possible to squeeze more GBW out of the IPS with higher Hfe and lower capacitance so C13 might be adjusted as well. KSA2690A should be a good replacement for the VAS as 160Vceo should suffice but it would need heatsinked at 7mA * 60V=420mA. They do not have metal tabs but rather solid plastic TO-126. (I have some lying around too.
All the trouble I've ever been in started out as fun...... |
| Transistor replacement | grandville45 | Parts | 30 | 1st April 2010 05:50 PM |
| Looking for replacement transistor | kockaboy | Parts | 4 | 15th October 2008 04:51 PM |
| transistor replacement | xcicc | Solid State | 0 | 16th August 2008 10:05 AM |
| Transistor Replacement | portlandlay | Solid State | 26 | 14th December 2005 07:46 PM |
| Page generated in 0.10001 seconds (65.43% PHP - 34.57% MySQL) with 11 queries |
