I am looking for pattern or something similar for proton am-30 Amplifier
Antonello |
#2 |
Hi Antonello,
Attached is a schematics not exactly AM-30's but close to it. In red the actual designation and type of transistors of AM-30's. Mine had the right channel blown. I fixed it by changing output transistors and their drivers and Q509 too. Note that I replaced output transistors 2SC3281 and 2SA1302 by MJL3281 and MJL1302 and it works fine. You said you always burnt a driver; make sure to replace insulating stuff as the driver heatsink can get in contact with the main heatsink. Before powering on the amp, try to disconnect the final stage power (unplug the connector the closest to the main heatsink), power on it and check the various voltages. You can compare with the other channel voltages. This check can help you find issues with less risk to blown again the final stages. If this check looks correct, plug again the connector and cross the fingers Laurent. |
#3 | |
Hello thanks for the pattern just saw him today but in between I had already burned more transistors .. Cable ... not foot the first time that this had a hand I found the 2 MJL 21194/21193 short equity and its drivers I replaced them and it worked well ... then in an Italian forum, but one said that the transistors were not so original tarot So I ordered them from milano (I live in Sardinia) I get them to return and this time I'm in this mess wrong position of the first pilots Then I did not realize that a transistor was shorted Last time I burned because the transistors were wrong position Once again I am blown because I forgot the mica insulation I finally found myself with no more spare parts and are still at a standstill I also replaced the various bc 550/556 / and more ... I checked the resistors and diodes, comparing them with the good channel ... I also replaced the trimmer with the same value of what is working in the channel ... but I have not solved ... Now I have to go to Rome for the holidays when we return to meddle ... Thanks Laurent for the scheme Antonello |
#4 | |
| Wanted: 30-0-30 500VA transformer x 2 (UK/EU) | firestorm | Swap Meet | 0 | 12th January 2011 01:30 PM |
| Proton AM-30: Blown 2SA1302-2SC3281 | echopapa | Solid State | 2 | 29th December 2010 08:16 PM |
| Premier Speaker Stands ... by Paradigm -- model: S-30 (30"tall) | Livin | Swap Meet | 10 | 3rd February 2009 02:08 PM |
| Q: Zen-lite with -30~+30 voltage rail? | Peter Huang | Pass Labs | 2 | 7th August 2007 11:42 AM |
| 2 x 500VA 30-0-30 Toroidal Power Transformers | WALTER BURKHARD | Swap Meet | 4 | 30th July 2005 01:01 PM |
| Page generated in 0.09955 seconds (79.98% PHP - 20.02% MySQL) with 11 queries |
