Simple Symetrical Amplifier
Old 29th September 2011, 09:37 PM   #981
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by psychosteve72 View Post
thanks lazy cat, did you just mean the green junction dots? if so hows this one?
Better now
So first we'll clear out sch and you'll correct the PCB in accordance to:
- R11, R18 goes out
- C3 should be 4,7 uF so it needs more space around on PCB
- T2 you must change drain and source pin !
- please provide two 1N4007 in series diodes, parallel to C4
- please add one extra 1 uF cap parallel to C4
After sch + PCB correction I can check.
Old 29th September 2011, 09:42 PM   #982
Lazy Cat's Avatar
Originally Posted by a.wayne View Post
... can i substitute the NJL outputs for MJL , is there a difference ...?
You can, but than you will need linear Vbe multiplier (one TO-126 BJT, one diode, one multiturn trimmer, two resistors) instead of four thermal-track diodes. No big deal.
Old 29th September 2011, 09:48 PM   #983
a.wayne is offline a.wayne  United States
Sin Bin
Hello LC,
Can we do the calculations for the necessary values with an PSU output of 35volt, i already have 1000va trans @ 25v..
regards,
Old 29th September 2011, 10:00 PM   #984
Lazy Cat's Avatar
Hello LC,
regards,
By the +/-35V supply voltage to an output stage you will get maximally 300Wrms/1ohm, that means 25Vp and 25Ap, so you will need 4 pairs of the output BJTs and a lot of cap filtration in PSU.
Old 29th September 2011, 10:02 PM   #985
Sin Bin
I have currently 200K/ uf/ch ... let me know if more is necessary ...
4 prs sound small for such a load, as do the power output from an 35volt PSU, can i ask how you are arriving at the 25 volt out from 35 volt supply...?
Old 29th September 2011, 10:17 PM   #986
Lazy Cat's Avatar
4 prs sound small for such a load, as do the power output for an 35volt PSU, can i ask how are you arriving at the 25 volt out from 35 volt supply...?
100 mF per rail? It is OK
Well realistically is like that. 35V rails voltage potential (idle) -10V (rail drop + Vcesat) at 1 ohm load and you will get 25Vp and 25Ap unclipped level at amp's output and that is exactly 312,5 Wrms on 1 ohm. Four pairs BJT-s like 2SA1987/2SC5359 can handle that peak values without problems.
Old 29th September 2011, 10:51 PM   #987
psychosteve72 is offline psychosteve72
thanks Lazy Cat,
so the extra diodes are in, but didnt know which way round? but that an easy switch. extra caps in, resistors taken out and switched round the fet.
how does it look now?
thanks, steve.
Old 29th September 2011, 10:58 PM   #988
Lazy Cat's Avatar
1N4007 oposite direction, T2 is OK, funny program you are using.
Old 29th September 2011, 11:10 PM   #989
swapped diode round,
program is eagle lite on an ubuntu linux pc.
thanks for the help, steve.
Old 29th September 2011, 11:30 PM   #990
Lazy Cat's Avatar
One more thing regarding PCB:
- Q1 and Q3 have to be face to face glued together. This is mandatory.
- Q2, Q4 each should have small heatsink, also mandatory.
- T1, T2 probably there will be Al L-profile fixed to heatsink? Provide good thermall contacts ...
That's it. Bye
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
